savin 9922 sc322
  • 20yeartech
    • Sep 2025
    savin 9922 sc322
    i have a savin 9922 i replaced the pcu and cleaned out toner from
    machine an around laser unit. turned it on a have an sc322 code.
    i have taken the laser unit out and put in a different machine .it works fine
    replaced bciu board and harness from bciu board to laser unit. still have sc322 code. any other suggestions would be appreciated.
  • Claudio
    • Feb 2007
    • 235
    May have a bad pcb.
    Try calling Hytec Dealer Services in Florida.
    They have excellent Ricoh support for troubleshooting which pcb may be bad. Speak to Lee.
    Claudio
    • Baphomet
      Copier Technician
      • Aug 2008
      • 293
      I'm don't have a manual for this machine so I cannot provide service codes; but if you reset and initialize the beam pitch data you should be able to remedy the code. This is usually required on Ricoh products when you remove and install a laser unit. You probably just got lucky with the machine you tested it on ... I think the adjustment will correct it.
      • lvsb
        • Aug 2008
        • 70
        The door switches may have failed. Replace the switches or use a lenght of wire to jump(bypass) them.
        I would be wary of checking them with resistance because they could be failing under load.
        • lvsb
          • Aug 2008
          • 70
          Baphoment,
          The 9922 uses a single laser no beam pitch adjustment required.
          • Baphomet
            Copier Technician
            • Aug 2008
            • 293
            Originally posted by lvsb
            Baphoment,
            Thanks lvsb. I should of known better, but sometimes the desire to help gets the better of me.
            • b003ace
              • Jun 2008
              • 78
              I'll second this. The laser power is run through the door switches, and if one is even the slightest bit flaky...
