Reset fuser sc code on pre 5-810
  • andy227
    • Jan 2013
    • 219
    Can anyone remember the procedure for reseting fuser sc's on older b/w machines that didn't have the sp 5-810 reset code. Was on a Aficio 1515 today and I couldn't remember how to reset an sc 542 after doing a fuser repair. There is a sc/jam reset, but that does not seem to reset the fuser. I seem to remember holding down two buttons while switching on the machine, or something along those lines. Thanks.
  • sandmanmac
    • 3980
    Re: Reset fuser sc code on pre 5-810
    • andy227
      • Jan 2013
      • 219
      There is no sp 5-810. It goes from 807 then 811. It has to be another way.
      • sandmanmac
        • 3980
        Ooops. My Bad. That's for the 1013.
        For the 1515, like most others, you just enter SP mode and power off/on
        If it's not resetting, then you must have another problem.
        From the manual:
        Aficio 1515.pdf
          • 37444
          Of course you must first repair what ever caused the service code.
          One other little thing, if it codes while you are in service mode, you must exit service mode, cycle power, wait for the code to come back up and then enter service mode. Power off while still in service mode.
          • Polarbear
            • Feb 2012
            • 1070
            From the manual:
            [ATTACH]38990[/ATTACH]
            +1
            Press the GREEN button!!
