MPC3003 noise
  • GeorgeBest
    • Jul 2009
    • 525
    MPC3003 noise
    Hi,
    An annoying squeaking sound when I do the SP5804-136 = Transfer Drum Motor K
    Even without the ITB and PCDU-K installed.
    Meaning motor replacement or checking the drive unit? (Hell of a job I think . . )
    Someone experienced this?
    thanks in advance
    • 37478
    Re: MPC3003 noise
    Usually something in the gear train.
    • Mark Bbb
      • Jun 2012
      • 1662
      Re: MPC3003 noise
      it's one of the gears of the TCB drive unit.
      • FrohnB
        • Jul 2017
        • 1919
        Re: MPC3003 noise
        Usually the annoying squeak we get is from the ITB unit. Disassemble, clean shafts, lube bushings. But if your squeak still persists without the ITB in, then I think you're on the right track with the gear pack. Have never had a squeak there (knock on wood), but have had a squeak on these models, Brand New out of the box, that ended up being a rusty shaft in the exit unit drive gears, which you have to get to from the back. These machines aren't too bad about accessing drive packs and what not from the rear.
        Omertà
        • cdabs
          • Oct 2011
          • 12
          Re: MPC3003 noise
          Just been out to the exact same problem, just wondering if anynbody has managed to cure it?
          • FrohnB
            • Jul 2017
            • 1919
            Re: MPC3003 noise
            Had one recently that would still squeak without ITB and such in it. Turned out to be Waste Toner Bottle. Hope this helps.
            Omertà
            • Paddy313
              • Aug 2018
              • 6
              Re: MPC3003 noise
              I replaced a Pipe:Assy (Toner Recycling) because of noise recently
              • sandmanmac
                • 3981
                Re: MPC3003 noise
                Wouldn't it be wonderful if the original posters would return with a report of how their issue was resolved and actually contribute to the consortium?
                George is the King of "Thanks in advance" as if it will somehow help someone else down the road, and almost NEVER posts back
                Interesting that he's always too busy to provide feedback, but NEVER too busy to ask for help
                Result: Miserable Rep, and on My Ignore List
                • cdabs
                  • Oct 2011
                  • 12
                  Re: MPC3003 noise
                  Thanks for suggestions!
                  I've just found RTB RD147104a and ordered the silencer. Will let you know how I get on and try the WTB etc if needed
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    Re: MPC3003 noise
                    He's also the "King of the Red Cards" and now you know why
                      • 37478
                      Re: MPC3003 noise
                      He would most likely have even more if he wasn't on so many ignore lists.
                      • Zaxxon
                        • 608
                        Re: MPC3003 noise
                        Please start you post with brand, model, problem.
                        • cdabs
                          • Oct 2011
                          • 12
                          Re: MPC3003 noise
                          Quick update on the issue, we ordered the silencer from the technical bulitin - didnt do anything noise was still there.
                          Was pretty sure it wasnt related to the WTB - the sounnd was comming from the other side of the machine.
                          Swapped out the ITB unit and no change.
                          Swapped PCU and Dev - squeek gone
