Help please with bad blacks on a MPC2503 - My Nemesis!
  • dave w
    • Jun 2015
    • 230
    Really need some guidance please as all my knowledge on MFPshas been exhausted due to my experience.
    I have a MPC2503 that is printing off bad quality blacks andit fades with use.
    Counter color 27772 b&w 107345
    Parts fitted = new pcu + dev unit + itb + charge roller - Toner hopper was swopped over from a working machine.
    Black looks good on page counter, in sp mode under printer a test page was generated and blacks look good apart from one line
    Pics of samples.
    orig test pic
    copy of color chart - color and black & white
    when a run a test print SP1-103-002
    you can see one black line affected
    when the ProCon is run the ProCon ok? shows 1111111 which I read as ok
    same with IBACC ok? & TD sens init ok?
    no faults detected.
    Laser unit removed and checked for dirt & dust.
    really need help here.
    • 37429
    Re: Help please with bad blacks on a MPC2503 - My Nemesis!
    Assuming that the Printer SP 1103-2 print is fed SEF, it looks to me like you have a problem with the black development unit or there is something on the black laser shield glass. When you use high lint content (crap) paper, paper lint will get into the development unit and create clumps that will clog the doctor blade gap. You can try cleaning the doctor blade but if the problem keeps coming back, the only solution is to replace the development unit as Ricoh does not sell developer for the 03s.
    • Mark Bbb
      • Jun 2012
      • 1662
      you have forgotten to install the rear pcdu cover of the black pcdu.
      OR you didn't shake the development unit well...
      Try this out, please.
      • Ricohguy
        • Sep 2012
        • 48
        I can almost guarantee this is correct.
        • Zaxxon
          • 608
          This get me vote!
          Please start you post with brand, model, problem.
            • 37429
            Originally posted by Zaxxon
            This get me vote!
            I am wondering, since the black development unit has a recommended PM cycle of 600K and it only had a total of 135K on the black development unit, why was it replaced unless the problem already existed?
            • Polarbear
              • Feb 2012
              • 1070
              This get me vote!
              +1 on the rear cover with the copper contact. Experienced this first hand and it had me beat for a week before I figured out what I had done wrong!
              Sent from my SM-G925F using Tapatalk
              Press the GREEN button!!
              • copier tech
                • 8133
                Yes you get this exact print quality issue if you dont fit the rear cover on the PCDU.
                If the cover has been fitted check the copper bias contact is OK.
                • copier tech
                  • 8133
                  Wrong, the MPC2503 dev PM life is only 120k
                  • Cipher
                    It's not easy being green
                    • May 2006
                    • 1309
                    I once had a real shit of a colour reg issue on a MP C2503 where processed K text made up of CMY was ghosting near the rear.
                    Turned out it was a new and recently fitted colour drum unit that was faulty.
                    It looked fine on inspection but this one drum unit was producing skewed prints.
                    It caught me out as you really don't expect a new drum unit to be faulty in this way.
                    Hence you end up ruling it out early on in troubleshooting and looking at other things.
                    • dave w
                      • Jun 2015
                      • 230
                      BIG thanks and I cannot believe I missed it, It was the rear PCDU cover!.
                      Hang my head in shame.
                      This forum is a life saver.
                      I'm off not to find a dark corner to stand in.
                      • copier tech
                        • 8133
                        Originally posted by dave w
                        [ATTACH=CONFIG]39052[/ATTACH]
                        Dont feel too bad one of my engineers threw that cover away, it took multiple visits before I sugested the cover was left off!
                        • Cipher
                          • May 2006
                          • 1309
                          When one of our techs made the same mistake he actually threw the rear cover away! we had to order one in.
                          I took the piss out of him for months lol.
                          • sturmtrooper
                            Copier Combobulator
                            • May 2016
                            • 587
                            You can really tell that these are "budget" minded.
