MPC4504ex Borderless printing
  • copier tech
    • 8220
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: MPC4504ex Borderless printing
    You'd be best doing SRA3 booklets and trimming them to size.
    Hit it.
    • sturmtrooper
      Copier Combobulator
      • May 2016
      • 587
      You have to leave some leading edge white space for the fuser or the paper will stick to it. Going to the edge of the sides and trailing edge is the best you'll likely get. Even the four color printing press we have doesn't do all four edges.
      I believe printing on oversize paper and then cutting to the desired size is the industry standard.
        • 37628
        You can use SP 2103-003 and 004 to adjust the left and right margin erase. DO NOT change the lead edge erase to less than 2mm or you WILL get fusing exit jams. If you are doing 2-sided, the same applies to the trail edge. It you are doing full bleed color, do not set to less than the default of 4.2mm.
        • copier tech
          • 8220
            • 30550
            You have to print on larger paper and cut it down
              • 37628
              It just means that the driver itself is not going to add a border to the document.
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  You could always use the guillotine on the salesman who told them it would do true edge-to-edge.
                  • copier tech
                    • 8220
                    • SargeNZ
                      • May 2012
                      • 263
                      If the client is big enough, this may be a good chance to look at some automatic slitter/cutter/creaser options that are about, we have a few DUPLO machines in the field that are pretty neat.
                      • copier tech
                        • 8220
                        • Tecnicopia
                          • Jun 2015
                          • 31
                          Yep, did it to a MP C4503.
                          SRA3 need longer transfer roller.
                          Enviado desde mi Redmi 4X mediante Tapatalk
                          • LNorris
                            • Sep 2008
                            • 645
                            make the salesman prove it can
                              • 37628
                              Quick method is to set lead and trail edge erase margin to 0 then have the customer try to run 10 full bleed color prints without jamming.
