office365 scan to email
  • nokktekk
    • Mar 2018
    • 44
    [Misc] office365 scan to email
    How are are you all? Please can someone tell me if it is possible to setup scan to email using office365 on the Mp 201spf and Mp 4002? Thank you all in advance.
  • sandmanmac
    • 3990
    Re: office365 scan to email
    I can't speak for everyone....but I'm ok. Thanks
    MP201: no
    MP 4002: yes
    I'm guessing you'll have many more questions about this. Search the forum about scanning with Office 365, there are MANY threads.
    There are also many workarounds for machines, like the MP201, that don't support encryption, which again, is covered in great detail in dozens of threads.
    • copier tech
      • 8237
      I would steer clear of O365 on these old models, you'll most likely have issues & will need to ensure they have the latest firmware.
      You'd be better of using SMB or gmail to scan.
        • 37652
        This Microsoft Office Support document should help.
        How to set up a multifunction device or application to send email using Office 365 - Office 365
        • SargeNZ
          • May 2012
          • 263
          I don't think the 201 will support the TLS/SSL requirement for Gmail.
            • 37652
            That depends on how you set it up. Gmail does have a restricted port 25 option. I have been setting machines up to use it for years. See attached.
            Send email from a printer, scanner, or app - G Suite Administrator Help
