2051 glitchy settings menu problem
  • abdelrhman93
    • Aug 2025
    frist time to face this problem and i don't know where to start
    i did a all memory clear reset nothing changes
    thanks in advance
    Sent from my Lenovo TB3-710I using Tapatalk
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: 2051 glitchy settings menu problem
    Argh never seen a ops panel screen go like that before, it's like it's just crashed.
    To be honest doing a memory all clear has probably made things even worst I'm afraid.
    But...
    • Try seeing if you can get to the WIM and see if there is service code displayed that will point you in the right direction.
    • Try reloading the firmware.
    • Or maybe try another ops panel, controller or HDD.
    It's a bit of a weird one as a MP C2051 does not have fusing oil, so I've no idea why it would display that message. :-S
      • 37628
      Corrupted control control panel board memory/firmware. Reflashing the LCDC firmware might help. You will have to use the Remote firmware through WIM. If that dies not correct the problem, you will need to replace the board.
      If you did an All Memory Clear, SP 5801-001, I hope you have the birth certificate.
      • copier tech
        • 8220
        [QUOTE=abdelrhman93;596369]frist time to face this problem and i don't know where to start
        thanks in advance
        All memory clear should be the very last thing to try.
        Update ALL the fw modules would be my first step.
        • cadillac2
          • Oct 2015
          • 42
          try formatting the HDD 5832-001 and then do 5853-001 to restore firmware data to the HDD
          • Mark Bbb
            • Jun 2012
            • 1662
            Could also be infiltration of a fluid.
            Replace or swap op.panel, i would start with.
            • cadillac2
              • Oct 2015
              • 42
              that seems unlikely, because the bizarre "fuser oil" message could not possibly be generated this way. It has to be software
              • abdelrhman93
                thank you all for responding to my post
                it was very dump from my side
                some asshole change the panel because the fax button cracked with defferent model panel [emoji36]
                I think 2050
