Aficio MP C6501 "Add Toner" Issue
  • Pokerking1993
    • Jan 2017
    • 17
    Hello all,
    I have an MP C6501 that will not get rid of the "Add Toner" message. I have already replaced the toner dispenser (idk what to call it but the large holds for the toner which houses the toner pump). I have taken apart the drum and everything spins as it should.
    Any ideas?
  • Stormhammer
    • 150
    Re: Aficio MP C6501 "Add Toner" Issue
    There's a TSB about this, actually.
    In it, it describes the following causes:
    SP Modes 3812 & 3815 display incorrectly. Or, SP3817 is not a value of 0.
    White rubber hose from the toner cartridge outlet to the sub hopper is clogged.
    The toner end sensor is defective.
    I would also check the TD sensor or better yet, push this machine down a hill and put it out of its misery.
    • anothertech
      • 1766
      If all of the developers were not initialized successfully, toner will not add, check in service mode to see if they were initialized.
      • TonerMunkeh
        Professional Moron
        • 3865
        Set SP3410 for the affected colour to 10 and reboot, should sort it.
        Hit it.
