Ricoh DD 6650P with SC-509
  • T911
    • Jun 2007
    • 628
    Checked on the slider lift motor in the delivery area for debris but no luck, ran the motor in sp-090 and it was fine couldn't find the sensors in sp5 to test so i want to order the motor and limit sensor but i dont see it in the parts manual. If I'm missing something to look at help is much appreciated. See Attached Thanks
    • 37556
    Re: Ricoh DD 6650P with SC-509
    As near as I can tell by looking at the Detailed Description, the Point to Point and the parts catalog, it is item 6 on Paper Exit Section 3. From the P to P it is on the same harness as the job separator motor, item 3. The bracket looks the same as item 8 with item 5 attached. You might want to download the Detailed Description manual.
