Password reset on a Ricoh MP 3554
  • sibleyrc
    • May 2015
    • 4
    #16
    Re: Password reset on a Ricoh MP 3554
    Originally posted by AMS
    This works on 4502 so it may work.. Go into the factory service mode. Not the standard service mode. Reset,1,4,3.clear, hold clear again for 5 seconds. Then your in factory mode. sp 5846-46. Execute that and when you turn the machine off and back on just enter your new password or just hit OK to enter no password. hope this is what your looking for. The sp may be different in the 04 then the 03's but the name should be the same.
    This worked on a MP 2352 also. Thanks for this post, I've been trying to find the answer to this issue for a while. Occasionally when we go on a service call to a machine where the local IT has changed the login to the MFP and the offending party has moved on to another job and no one else knows what it was changed to.
    • skinnyb
      • Jul 2008
      • 291
      #17
      Originally posted by Oze
      +1
      +2
      Sent from my VS987 using Tapatalk
        • 37587
        #18
        If you idiots keep disclosing company confidential information in public posts instead of Private Messages, one of these days Ricoh is going to change it as part of a firmware release everyone is going to be screwed. Either that or an unethical competitor is going to start hacking machines.
