MPC3500 SC548 already changed fusing unit and now Machine Offline
  • KaiRai2018
    • Sep 2017
    • 13
    [Error Code] MPC3500 SC548 already changed fusing unit and now Machine Offline
    MPC3500 SC548 already changed fusing unit and now Machine Offline. Please help.
  • LNorris
    • Sep 2008
    • 646
    Re: MPC3500 SC548 already changed fusing unit and now Machine Offline
    did you reset fusing code?
    • KaiRai2018
      • Sep 2017
      • 13
      I could not reset it as I won't be able to go to the service mode. Stuck-up. Please help.
      • FrohnB
        • Jul 2017
        • 1919
        You can still enter service mode even with the code displayed.
        Omertà
        • Cipher
          It's not easy being green
          • May 2006
          • 1309
          Rotation error.
          There are a couple of sensors on the machine. Normally one of them gets knocked out of position if the fusing unit does not go in perfectly square.
          The photo sensors were modified to have a wider gapping to prevent catching them accidentally.
          The firmware was also changed to improve the detection timing of SC548/549.
          Of coarse SC548/549 can also occur if the fuser needs servicing and the orange foam roller under the belt has flat spotted or the ferrite roller is worn out.
          The sensors in the video are the wider type.
