MP2501 ovetone after toner replacement
  • Polarbear
    • Feb 2012
    • 1070
    Hi all
    Searching CTN I have only come across light copy issues on these boxes.
    We have recently come across a spate of ones that overtone as soon as a toner is replaced.
    It clear after about 150-200 copies....
    All parts in the machine are OEM (dev, drum, etc) so that is not an issue.
    Have any of you had the same? have you come across a fix for this?
    I would appreciate any feedback greatly, as we have one customer that wants to toss their box because they have quite high usage of their machine, so they see this condition very often.
    Press the GREEN button!!
    Re: MP2501 ovetone after toner replacement
    Originally posted by Polarbear
    Hi all
    OEM toner?
    what's the life count on the dev unit?
    • cadillac2
      • Oct 2015
      • 42
      when its overtoning, are there traces of developer on the page - light black dust that didnt get fused?
      • Mark Bbb
        • Jun 2012
        • 1662
        I have noticed this issue also.
        On the PCDU there is a cussion, where the toner supply unit drops in the toner.
        That cussion might loosen and blocks the toner hole.
        • Polarbear
          • Feb 2012
          • 1070
          Mark would that not cause light copies? Or am I missing something?
          Sent from my SM-G950F using Tapatalk
          • Mark Bbb
            • Jun 2012
            • 1662
            Indeed, it would.
            • Polarbear
              • Feb 2012
              • 1070
              Indeed, it would.
              Our condition is the other side of the scale where it overtones after New toner is installed and only stabilises around 150 copies later.
              • TonerMunkeh
                Professional Moron
                • 3865
                Which developer are you using? B121 or D158?
                Hit it.
                • Polarbear
                  • Feb 2012
                  • 1070
                  B121. We used D158 originally and had light copy issue.
                  Then switched to b121 from then and all went well. There are just some out of the whole fleet who behave this way. I am at present aware of 2 boxes that do this.
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    Pick one as a victim and fit it with the D158 dev, then run the arse off it and change the bottle. See if the fault persists.
                    Hit it.
                    • Polarbear
                      • Feb 2012
                      • 1070
                      Worth a try. Thanks.
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        P.bear: it could be that the toner entry hole on the pcdu is partially blocked with that cushion.
                        So, the copies are fine but at the same time toner is everywhere...
