SC 220 After Clean
  • printertnc
    • Jun 2015
    • 68
    SC 220 After Clean
    Goodmorning everyone.
    I have a very strange problem with a Ricoh Mp 5002.
    The machine has 465,000 copies.
    I cleaned it because it was full of toner on all sides. I removed the fuser, the development unit, the transfer belt and the laser. The laser has the whole block, and the slide is cleaned by hand. After reassembling everything, and after having remounted the laser, I get a SC 220 error at startup. I checked all the wiring and everything is OK. I read that this error occurred to other users, how did you solve it? I also read that it can also depend on the front doors, but it's all closed.
    Can someone help me?
    Thanks so much
  • copier tech
    • 8195
    Re: SC 220 After Clean
    The ribbon cables can be very fragile check you have not damaged them.
    Also did you use a vacuum cleaner to clean up the spilt toner? this may have caused a static change & damaged a board etc.
    • printertnc
      • Jun 2015
      • 68
      I have not used any vacuum cleaners. I removed the whole part of the laser block (was full of toner), cleaned by hand, and remittance and I have this error. I have not touched cables or wiring. The laser card in front was full of toner, clean with a compressor without too much force
        • 37560
        The MP 5002 does not have a ribbon cable going to the laser diode unit.
          • 37560
          Thanks so much
          SC 220 is a laser synchronization error. If you disassembled the laser unit to clean it, there are a number of problems you may have caused. You may have dislodged one of the mirrors causing an alignment error. You may have left the synchronization detector board disconnected, you have to remove the entire laser housing to check as it is at the back. If you removed the laser diode unit from the laser housing, you are going to have fun trying to get it back in proper adjustment. The screw D on the image in the service manual is an adjustment screw that is precision adjusted at the factory. The LD unit should only be removed if it has to be replaced. You are going to have to follow the adjustment procedure in the service manual.
          If you need to clean toner off the LD unit, it should be cleaned while still attached to the laser housing unit using a camera lens brush. https://static.bhphoto.com/images/im...00_1176843.jpg
          • copier tech
            • 8195
            Ribbon cables in general, not sure how far the poster went with his strip down!
            • printertnc
              • Jun 2015
              • 68
              • Wild Bill
                • Jul 2005
                • 774
                You need to open up the laser and clean it. If its as bad as you say that is the problem
                Izzy
                • ridgemill
                  • Sep 2017
                  • 191
                  Some laser units have electrolytic capacitors on the rear, make sure they haven't been broken off when removing the unit.
                  The synchronisation board is at the rear of the laser unit, make sure that the connector is seated fully. If it still doesn't work you may have to order a new board: D009-5325
                  • JOLYNAR
                    • Nov 2012
                    • 44
                    Replace laser unit
                    Inviato dal mio RAINBOW JAM 4G utilizzando Tapatalk
                    • blazebusiness
                      SanDiegoCopierRepair.com
                      • 1257
                      Thanks so much
                      Could be something simple............Many SC 220 codes that appear after removing and cleaning the laser occur because the laser unit is just no longer seated properly.
