Using drums and fuser from a C830DN on a mpc3002
  • fshead
    • 2356
    #16
    Re: Using drums and fuser from a C830DN on a mpc3002
    Originally posted by sandmanmac
    Haha...we have 120v in our igloos up here.
    I only have a handful of these particular units out, and none are in very high volume locations, and they all had such low meters when I installed them, that I've yet to reach PM on any of them, so I can't really answer that.
    I've seen no charge roller issues myself at least up to 200K +
    Outside of the fuser sleeve design issues i like these machines...
    • Mark Bbb
      • Jun 2012
      • 1662
      #17
      [the ITB all you do is bend up a stopper in the machine above the ITB or swap over the top plastic covers & remove a green knob.]
      ITB: just remove the middle plate from the spc830 ITB and it's compatible for mpc3002.
      • sturmtrooper
        Copier Combobulator
        • May 2016
        • 587
        #18
        consumables aren't rated to last as long on the printer side compared to copier... why would you weant to install USED items in a machine?
        The rating is lower because the customer is expected to replace them at the first sign of trouble instead of having a tech determine how bad it actually is.
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          #19
          Originally posted by fshead
          thats is where i am at,with trying to place a machine where costs rule supreme..
          Most of my accounts are low meter and only the 60cpm b/w i service are doing 20kto 40k monthly..
          I saw something stating do not empty the drum waste toner bottle..
          Is there a reason for such?
          looks like it has a tape seal after you pull the 4 screws off.
          You can happily empty waste toner bottles on the 02 series but NOT the 03
          • davel
            • Oct 2011
            • 1081
            #20
            SPC830 waste bottle will not fit in MPC
            • fshead
              • 2356
              #21
              i m kinda curious why not on the c3003 series?
              i have emptied it by the small hole but considered removing the screws and razor blade the tape
              seal..This is only when i get a lease return unit and go through everything before wrapping it for delivery..
