Using drums and fuser from a C830DN on a mpc3002
  • fshead
    • 2378
    hi
    I have never seen a c830dn printer but saw that you can make the fuser unit work in a mpc3002.
    Has anybody done that and how about drums,dev units ITB unit?
    I only asking because i might have a lead on some cheap printers that i would part out.
    thanks
  • copier tech
    • 8238
    Re: Using drums and fuser from a C830DN on a mpc3002
    Yes this is correct, you can use the fuser unit & ITB from a SPC830 to fit in an MPC3002 etc.
    The fuser you just swap the jumper over from the old fuser & the ITB all you do is bend up a stopper in the machine above the ITB or swap over the top plastic covers & remove a green knob.
    Don't think the drums fit, but I use part D0292256 & modify this to fit as a block or colour
    • cadillac2
      • Oct 2015
      • 42
      You need to swap over the plate w/harness on the 830 fuser.
      just follow these directions : spc830dnfuserSWAP.pdf
      • copier tech
        • 8238
        You can also fit the MPCxxx4 PCU into the Metis MPCxxx3, the 04 drums are around $120 cheaper.
        • Imprestik
          • Aug 2012
          • 297
          The SPC830DN drums are a direct replacement for any 02 series device
          All that's required is to pull off the TD sensor for every dev unit and stick it back on the maintenance kit PCDU and snip a little locating lug on the bottom of the front cover so you can push the PCDU into the device and off you go
          Been doing this for years now, you can even use these on the 01 series devices as well
          Forgot to also mention DO NOT USE THE fusing kit of the MPC3002, MPC3502 as the fusing belt with lamps are different and will give you SC553 errors
          • fshead
            • 2378
            thanks ALL
            can you use the printer fuser unit in a mpc3002?..
              Originally posted by fshead
              hi
              thanks
              consumables aren't rated to last as long on the printer side compared to copier... why would you weant to install USED items in a machine?
              • copier tech
                • 8238
                In the UK we use the SPC fuser in the MPC no problem because we different voltage.
                • sandmanmac
                  • 3990
                  While I've not dealt specifically with this model either. I've done it many times myself with other printers, so I'd suggest that he, like I, can probably pick these units up (often with only a few thousand pages) for literally next to nothing. Part them out, and use those parts in a customer's machine, save them hundreds of dollars, and still make himself a decent buck while he's at it.
                  What's wrong with that?
                  We don't all work for dealers, and we don't all have access to genuine parts through 'normal channels' when we need them, so we have to find other ways, but my customers (at least) usually appreciate that I do.
                  • fshead
                    • 2378
                    And for me I only sell lease return machines and sometimes i will pull parts from a machine that
                    has other issues,ie blank screen,smashed panels or missing boards..
                    So having other options as buying brand new from local dealers inde guys like myself get
                    taken for a large markup..
                    • sandmanmac
                      • 3990
                      Same here, Andy.
                      We're in a very similar situation
                      • fshead
                        • 2378
                        are you 120v or 220 v up north?
                        I was hoping these printers would be cheap but my 2nd option for machines
                        wants as much as a mpc3002 and i will have to wait till my main seller gets some in..
                        It make life easier when you have spares of everything to swap and move on...
                        What count are you seeing on the c3002 original k drums b4 seeing lines from charge roller?
                        • sandmanmac
                          • 3990
                          Haha...we have 120v in our igloos up here.
                          I only have a handful of these particular units out, and none are in very high volume locations, and they all had such low meters when I installed them, that I've yet to reach PM on any of them, so I can't really answer that.
                          I've seen no charge roller issues myself at least up to 200K +
                          • Oze
                            Ricoh Fanboy
                            • Jul 2008
                            • 1663
                            Same in Australia.
                            We use the spc830dn fuser kit,b/w pcdu kit and the colour pcdu kit.
                            We also use the 830dn ITB assy in '02 machines AND '01 machines.
                            Most of our MPCxx02 machines are coming off contract this year so although the printer unit parts are lower yield we fit them in the machines about to end their contract.
                            • fshead
                              • 2378
                              Originally posted by Oze
                              Same in Australia.
                              thats is where i am at,with trying to place a machine where costs rule supreme..
                              Most of my accounts are low meter and only the 60cpm b/w i service are doing 20kto 40k monthly..
                              I saw something stating do not empty the drum waste toner bottle..
                              Is there a reason for such?
                              looks like it has a tape seal after you pull the 4 screws off.
