ADF- Ricoh Aficio MP 6500
  • Vladika
    • Dec 2016
    • 40
    Hello, I have a problem with the machine Ricoh Aficio MP 6500. When I put paper in ADF, sometimes paper stuck. The machine gives me a message that it will be restarted, also if I open the feed cover shows me the same message, but not always. Can it be up to BCU board or something else can maybe cause that problem?
  • anothertech
    • 1769
    Re: ADF- Ricoh Aficio MP 6500
    Sounds like you need to place a service call.
      • 37489
      If the machine is rebooting automatically, check the settings of SC 5875-002.
      • anothertech
        • 1769
        Print out a copy of the SMC report to see what code the machine is having that is causing the reboot.
