savin 9021d installing post script
  • clark
    • Sep 2016
    • 109
    I need to install postscript. I know its on a sd card. I see 2 slots. top has fax option and lower card just has a numbers on the card. can I just replace the fax card ?
    thanks for the help.
  • sandmanmac
    • 3979
    Re: savin 9021d installing post script
    Yes, if you don't require the fax option.
    If you do, then the process becomes more complicated
    • zed255
      How'd ya manage that?
      • 1024
      Merge applications if required. On older products applications needed to be merged to the Postscript card, on newer products it does not matter which direction merging is done.
      • clark
        • Sep 2016
        • 109
        Thank you for the help.I will order part.
          • 37289
          A word of advice, it the card in the bottom slot is a JAVA card, you must stop the JAVA application in User Tools before removing it to merge the other 2 cards. If you don't, you risk having a toasted JAVA card and control board. Rather expensive mistake.
          • copier tech
            • 8131
            Out of interest why would a MAC user need to print to this old b/w machine!?
            • fshead
              • 2360
              Some people just love MACS...........Swear by them..........I have lawyers who use them and
              what graphix application would they even need...
                • 37289
                Not necessarily a MAC user. There small regional hospitals that have information systems that require PostScript printers. Not all of them can afford to replace printers when they fail.
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  Quite true!
                  There are a ton of possible reasons as to why PostScript is required, other then Macs being involved.
                  Not related, but here is a pet peeve of mine:
                  I see "Macintosh" abbreviated incorrectly as "MAC" on CTN almost daily.
                  A Macintosh (Apple) computer is referred to as a "Mac" (short for "Macintosh"). Only the "M" gets capitalized.
                  "MAC", on the other hand (all caps) is an acronym for "Media Access Control" (as in a "MAC address"), which is a networking term.
                  From Wikipedia: MAC address - Wikipedia
                  Rant over.
                    • 37289
                    Originally posted by KenB
                    Quite true!
                    Rant over.
                    It also stands for Machine Address Code which is the term I have always heard. MAC address has always sounded redundant to me.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      I like that definition better, too!
                      When I took my Net+ training back in 2011, it was Media Access Control then, at least in the course materials we used.
                      • copier tech
                        • 8131
                        • KenB
                          Geek Extraordinaire
                          • Dec 2007
                          • 3944
                          Linux and UNIX pretty much only do PostScript, too. VERY little PCL.
                          I remember a few years ago, there was a Konica Minolta Fiery that was PostScript only, and offered PCL as an option. That was a Color MFP.
                          Going back almost 20 years, the Canon iR600 (and the printer only version, the iR60) were PostScript only with the early version. Those were B&W, with embedded Fiery controllers. I think version 2.x gave it PCL.
                          • copier tech
                            • 8131
                            A lot has changed in this industry over 20 years!
                            • KenB
                              Geek Extraordinaire
                              • Dec 2007
                              • 3944
                              Quite true, but PostScript isn't going away any time soon.
                              It can do things that PCL (including version 6) simply can't.
