Ricoh aficio mp5500 scan to email error
  • Intone
    • Apr 2015
    • 68
    The machine is erroring out when trying to scan more than thirteen or so pages. Looked in settings through panel and web interface. Couldnt find anything that would work. Tried changing file types as well. Any suggestions? Thank you
  • Kimi
    • Feb 2018
    • 105
    Re: Ricoh aficio mp5500 scan to email error
    check max email size is set to off
    if so limit will be set server side
    • LNorris
      • Sep 2008
      • 645
      check to see if you are scanning in color as well.
      • Intone
        • Apr 2015
        • 68
        Don't remember seeing any email settings to change the max email size to off ? ... would you remember where that is and I can check that ...I also have a call into the IT people to see about the server ..
        Thanks a bunch for the suggestion ...
          • 37503
          User Tools - Scanner Features. Default is rather small. Back when most people were using dial up internet the limit was 3 to 5 MB for attachment on most email providers.
          • guitar9199
            • Sep 2016
            • 1100
            Most email providers (Yahoo/Gmail/etc.) have their email size "throttled" at 10 Meg. Also something to look for is to turn OFF "Divided" email...especially when using Gmail. Gmail doesn't like getting hit with 3-4 send requests just to break up a larger file.
              • 37503
              If you need to send large file the thing to do is scan them to folder then either use an app such as Dropbox to load them to the cloud and email the link or use gmail.
              • sandmanmac
                • 3981
                What error message?
                Is it something like "insufficient memory at destination......"?
                There was a thread posted not long ago about this. I'm not sure if it was updated with a solution.
                Coincidentally, I had the very same issue myself last week: 2 machines side by side (C4502 and MP2852), configured identically, but only one was erroring out.
                My fix was to do a memory clear on the scanner application and reboot.
                When I did that that, scanner journal printed out, and all was good again.
                I put all the scanner settings back the way they were, and they haven't had another issue.
                I'm not sure what the scanner journal was set to beforehand. I usually have it set to "do not print/ Delete Oldest", but it seemed like whatever it was, it somehow bunged up the scanner
                • Intone
                  • Apr 2015
                  • 68
                  Turning off the max email size did the trick ... thanks a bunch to every one for there input and suggestions ... I really appreciate everyone taking time to help out ...
                  Sincerely
                  Maurice
                  Intone Office Products
