MP301SPF: SD card authentication failed. font01.mod
  • Polarbear
    • Feb 2012
    • 1070
    Here is an interesting one.
    When booting the device, all goes well till shortly after the Copy icon appears on the display.
    Then a tiny text message appears in the bottom left corner: "Module authentication has failed. Please call service. Module name:font01.mod"
    We have flashed all the font files we could find on MYRicoh with the latest versions, but no luck.
    I am starting to think that there was an SD card of some sort in the controller and that this was removed, and that the device is looking for this sd card.
    Has anyone else come across this before? I would love to get rid of this message.
    Press the GREEN button!!
  • francisco
    • Nov 2009
    • 168
    Re: MP301SPF: SD card authentication failed. font01.mod
    change controler
    i had this same problem twice
    • copier tech
      • 8133
      Originally posted by francisco
      change controler
      • Polarbear
        • Feb 2012
        • 1070
        Hi
        Flashed all the firmware and there is nothing in any of the slots. That is the mind bend!
        Sent from my SM-G950F using Tapatalk
        • copier tech
          • 8133
          Hi
          Ok, how about a memory all clear? Nothing to loose on this basic b/w model.
            • 37422
            Hi
            Did you use the package firmware or individual modules? Package will not replace those modules that are the same version as on the package.
            • copier tech
              • 8133
              There is no package fw on this model only modules.
              • Jarken
                • 8
                HI, I have the same message on my machine right now,
                Have you resolve this Issue yet?
                Would like to know what was the outcome.
                I don't have a spare controller on hand.
                • prado
                  • Aug 2013
                  • 7
                  Have you tried the memory clear sp5- 801?
                  • francisco
                    • Nov 2009
                    • 168
                    • Juggy
                      Technical Support
                      • Sep 2007
                      • 101
                      We got ride of this message by using a NVRAM of same model in mpc305 machine. Could be corrupt nvram si try with a new nvram before going for controllers.
                      Sent from my LLD-AL10 using Tapatalk
                      • Juggy
                        Technical Support
                        • Sep 2007
                        • 101
                        It was similar case but was for a fax module. In a machine which didn't have fax in it
                        • Polarbear
                          • Feb 2012
                          • 1070
                          Hi
                          Afraid to say we took the advice given, and replaced the controller.
                          • firstly we flashed the firmware with fresh files from MyRicoh - no change
                          • Then did the (unthinkable) memory all clear - no change
                          • Replaced the controller and built over the existing nvram chips - all was well.
                          Which leads me to believe that the issue exits on the controller board firmware in some non volatile storage that we could not fix by firmware alone
