Ricoh MPC 3000 SC 995
  • Techos
    • Aug 2025
    Hi
    I was installing last week , a MPC 3000 in a customer's office , equipped
    with a MPC 2500. For obscure and stupid reason , i started the MPC 3000
    with the MPC 2500 controller board.Every thing was OK at this moment.
    Then i decided to reinstall in the MPC 3000 his original controller board,
    and that was the beginning of my troubles !!
    Shortly after being turned on, the copier displayed " SC 995" ( wrong
    controller board).
    I ordered another MPC 3000 controller board with new NV Ram, reinstalled
    it, but the SC 995 stilled there.A co worker told me to change the IOB
    card.
    I made a clear memory of the MPC 3000 but the problem is not solved.
    I think that the copier has in his memory, ( NV Ram from the BICU ?) the
    parameters, serial number of the MPC 2500 initialy installed.
    Any help would be warmly welcome !!!
  • CSI
    • Oct 2008
    • 73
    • Cipher
      It's not easy being green
      • May 2006
      • 1309
      Your co-worker is correct, but you should only need to replace the R59 fuse on the IOB board.
      That fuse blows when you try interchanging the controller boards.
      • Techos
        • Aug 2025
        Yes i am !!!!
        Great "Mad scientist" !
        Do you realy think this problem has no solution ?
        • CSI
          • Oct 2008
          • 73
          Try the Cipher's method, it costs nothing.
          • E Winter
            Have you changed the dip switch settings? The boards are usually the same but with different settings on the mice pianos. The correct defaults are mentioned in the SM.
            That NVRam on the BCU is another good point because some parameters, like the serial number gets verified with the NVRam on the controller. But afaik a wrong serial number is forcing another SC. Can you access the SP? What serial number is stored in there?
            • Techos
              • Aug 2025
              Hi all
              The solution was to install a MPC 2500 control board !
              I hope the customer will not verify the machine speed !
              • Lagonda
                • Aug 2008
                • 1649
                Been there, done that and I just hope the customer isn't counting the copier output with a stopwatch in his hand!
                • CopytecWitten
                  Same Problem, but we miss R59. Where is it?
                  Another solution is too update the nvram with MP C 2500 information. Is not so expensiv, but slower than the MP C 3000.
                  • thumper
                    SC995 fix
                    Press "clear all", 1,4,3,"C/S", then press and hold "C/S".
                    Then go to copy SP, then SP5882 (CPM) and change to the initial setting.
                    • TecnocopyVI
                      • 45
                      hi , i have inverse problem someone can i help me. please thank you
                      • thumper
                        SC995 fix
                        • TecnocopyVI
                          • 45
                          I have try to change 5882 but it is not changed . i have still SC 995
                          • thumper
                            I believe that "0" was the default. But mine was set at "1" so maybe that is the setting for your machine.
                            Also SP5882 is may not be available unless one enters this way.
                            • TecnocopyVI
                              • 45
                              SP 5882 in phase 1,4,3 i have change but the error come again
