New to SOP
  • mikadonovan
    • May 2008
    • 2931
    New to SOP
    Hi, All. I have my first machine with a SOP to set up (C307). Just a general question, what method (out of the 4) works best for updating firmware?
    NEVER ASSUME ANYTHING
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: New to SOP
    We just tend to update the machine side firmware using the SOP version and steer clear of the panel firmware (CHEETAH).
    Mostly because doing both blows out our run up times.
    Mainly just update the panel software if we have issues.
    • Zeldaman
      • Mar 2011
      • 946
      • copier tech
        • 8236
        Re: New to SOP
        Yes just update the fw as you normally would, first the package (this will also update the SOP which is important) then update any modules that were not included in the package.
        I also delete the default copy & scan apps & replace with the classic apps must easier for the customer to use.
        • Cipher
          It's not easy being green
          • May 2006
          • 1309
          Re: New to SOP
          Panel to 'normal' startup mode.
          1. SOP O/S
          2. SOP Apps
          3. Machine firmware
          4. Java SDK
          You can put it back to 'quick' startup afterwards but I tend to leave it on 'normal'.
          Tried all the methods, I personally stick with the old school manual way.
          Just because it's more modular and gives you a little more control over the update process.
          • mikadonovan
            • May 2008
            • 2931
            Re: New to SOP
            Thanks for the replies, Guys. I got 'er updated, and I am semi-familiar with the machine now, although I have yet to get the machine web browser to work. I don't know why you would need it anyways.
            • SargeNZ
              • May 2012
              • 263
              Re: New to SOP
              if you are handy with the @remote website, you can get your machine networked up in the workshop, set up @remote and push out a firmware update which will happily churn away while you do something else.
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                Re: New to SOP
                If there are to be any apps installed, such as GlobalScan, AutoStore, Doc Mall (now known as RCM), the Java and Cheetah (panel software) MUST be either current, or extremely close to it.
                Worth noting that Java also requires the System, Network, And Engine to be up speed, too.
                I have run into multiple issues when either was behind.
                Note that while SOP apps are supposedly only running on the Android panel, Java still comes into play. I had a very painful experience with an MP 402 and AutoStore a few months ago. Although the panel was current, Java was behind, and AutoStore wigged out until the Java got updated.
                • Kimi
                  • Feb 2018
                  • 105
                  Re: New to SOP
                  check machine has correct DNS settings, common mistake.
                  • mikadonovan
                    • May 2008
                    • 2931
                    Re: New to SOP
                    That fixed the browser, thanks. I still don't know why anyone would need it, not all web pages load up right.
                    • Kimi
                      • Feb 2018
                      • 105
                      Re: New to SOP
                      Try browsing to youtube, always gets a chuckle from the customer.
                      My guess is because the panel runs Android that the feature is built in, thats what i tell customers anyway.
                      • GhostInTheMachine
                        • Feb 2010
                        • 88
                        Re: New to SOP
                        Browser is needed for ICE (Integrated Cloud Environment) and other solutions
