mpc3001 sc682-11
  • Mark Bbb
    • Jun 2012
    • 1662
    mpc3001 sc682-11
    In the mpc3001 serv. manual there is no description of the -11 extension.
    mpc3003 says 682-11: problem with pcdu Bk...
    The pcu Bk and developer Bk were replaced 50K - 3 months - ago.
    Also the pcu Magenta.
    Is the only way to solve this issue replacing the pcdu Bk?
    Thanks.
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: mpc3001 sc682-11
    Customer called, "PCDU's not correctly set"... on display.
    So, I removed - and placed back - pcdu Bk, magenta and cyaan: no good.
    I did the same with the pcdu Yellow:
    solved...
    I have cleaned the charge roller yellow some 15K ago...
    Could that have been the reason of sc682?
    I don't know now if sc682 is solved, now.
    I keep you informed.
    That this intervention took place so quickly is because it's our neighbour...
    • Mark Bbb
      • Jun 2012
      • 1662
      It seems that this tread is going solo...
      So, customer called again: "sc682-11, press restart" ...
      After that: "pcdu's not correctly placed"
      So, my first question remains...
      • Mark Bbb
        • Jun 2012
        • 1662
        Some 5K ago i have abusively reset the yellow pcu...
        Could this be the reason?
        • Mark Bbb
          • Jun 2012
          • 1662
          solved:
          connector machine - pcdu Bk, was not totaly connected...
          • fshead
            • 2376
            Originally posted by Mark Bbb
            solved:
            i swap a lot of used drums in and out and have had the drum not set message but not the sc682 code.
            glad you got it right
