Re: Ricoh MP C4000 - Scan to Folder issue
Yes bingo.
Sent from my VS987 using Tapatalk
Checked the other two PCs. The NetBios setting is set as default but I did notice that SMB v1 was in fact enabled on both other machines. This further confirms that the MPC4000 only supports SMB v1.Leave a comment:
There is no SMBv2/v3 for this model. It's old enough they might not release any firmware for it as they just released smbv2/v3 firmware for the MPC4502/5502 machines...Leave a comment:
Attached FilesLeave a comment:
Another option if machine is to old to support firmware update to smb 2 or 3 would be to replace machine with a new model.Leave a comment:
It's clear you don't know crap about networking. Filezilla ftp server install on a local pc is COMPLETELY SAFE, it's not an external FTP site. If you got a Konica machine you can use Konica's ftp utility. SMB1 Has been BANNED by any IT tech or company per MS and the recent security problems worldwide. Future updates from MS will remove any option to even turn smb1 back on.
Sometimes you have to read.
Stop using SMB1 | Storage at Microsoft
Microsoft Offers More Advice on Disabling Windows SMB 1 -- Redmondmag.com
If SMBV1 has to be enabled to get a machine scanning try firmware first. Most newer machines, past 3 maybe 4 years, have firmware to fix this problem. Some machines you might be ablate Telnet into to turn SMBV2/V3 on. I have done this with several Ricoh type machines. If these do not work and FTP, email, and HDD scanning is out of the question make sure the customer is fully aware of any risk's there is enabling SMBV1. Best thing to do would be to have something in writing and or have the customer enable SMBV1 themselves. Myself I have not seen a computer get infected through SMBV1. I'm sure it has happened but is such a rarity that most will not be infected. But there is always that chance so enable at your own risk.Leave a comment:
A halfway decent IT can configure their network to block any outside exploit of SMB v1. Microsoft's purpose in turning off SMB v1 was to block malware coming from outside the local network/domain. The only time I had any problems with SMB scan to folder using SMB v1 was the start of the school year following Microsoft's release of the patch. A small number of copiers stopped scanning to folder. On checking their settings I found each one had one of the following problems:- Spelling error on the Domain name.
- Destination was set to IP Address.
- First DNS was not the primary DNS for the MFP.
Scan destination was to personal folders on one of their servers. In all three cases Active directory did not recognize the sender as part of the domain.
FTP can be equally as vulnerable as SMB v1. That is why many major corporations will not allow you install FTP of any type on their networks.
Microsoft Offers More Advice on Disabling Windows SMB 1 -- Redmondmag.comLast edited by bsm2; 04-21-2018, 11:39 PM.Leave a comment:
Used filezilla server or scan to email or update firmware on machine to support smb 2 or 3
Windows 10 tip: Stop using the horribly insecure SMBv1 protocol | ZDNet
Most likely after a future MS 10 update that feature as well as smb1 will be removed and permanently disableLeave a comment:
Don't worry so much about what version, just upgrade to the latest version of firmware.
On a Ricoh device just go into System settings, Network tab, Print List. Look under the SMB section and look for a line that has Client V3.Leave a comment:
Turning SMB V1 back on you may expose the computer to unwanted Malware. Turning this on ANY customers PC opens you and your company for legal problems down the road. As this was a MS security update NOT Recommended
Sent from my SM-G955U using TapatalkLeave a comment:
I will revisit and post an uodate as to my findings.
Most likely after a future MS 10 update that feature as well as smb1 will be removed and permanently disableLast edited by bsm2; 04-21-2018, 05:33 PM.Leave a comment:
Interesting as i've never had to change this setting from default on multiple Win 10 installations.
My laptop is set as following & scans via SMB fine.
net.JPGLeave a comment:
It's likely the 2 you were successful on have Network Discovery and File and Printer Sharing enabled....while the other doesn't. Check their network connection type...if the bad one is set to "Public" for the network, that'll block discovery.
You may also need to make sure the IPv4 protocol on the computer is set for "NetBIOS over TCP/IP" instead of "NetBIOS over DHCP". That'll mess up SMB scans as well.
Good luck.The non-working PC may also have SMB V1 disabled. If so you may need to either enable it or got the FTP option. To check goto Control Panel, Programs and Features, Turn windows features on and off, scroll until you see SMB V1. Put a check the box and reboot. Keep in mind that by enabling SMB V1 you may expose the computer to unwanted Malware. SMB V1 is being phased out in favor of SMB V2/V3.
1- Enable "NetBIOS over TCP/IP" AND
2- Enable SMB V1
Both were required, one without the other wouldn't work.
BTW, The Public setting was not the issue. The other two PCs were also set to Public. Although it was set to Public, Network Discovery and File and Print Sharing were both enabled for all machines.
Once again, THANK YOU!!!Leave a comment:
