Mpc5501 drums coated
  • mrfuser
    • 1617
    • 37484
    Re: Mpc5501 drums coated
    Sounds more like the drums need to be replaced.
    • mrfuser
      • 1617
      Did that three times and same result
      • mrfuser
        • 1617
        Even if we choose single color cyan or yellow we get magenta all over the page. Black and white is fine
          • 37484
          The transfer rollers for all 3 colors are raised together therefore during B/W the ITB belt is not in contact with any color drum.
          • tjvincent
            • 280
            I would try a transfer belt unit.
            • mrfuser
              • 1617
              Ok tried different transfer belt. Same result , magenta drum getting coated . Could it be a bad high voltage power supply?
              • tjvincent
                • 280
                Did you just replace the belt or the whole unit ?
                • mrfuser
                  • 1617
                  Entire unit replaced
                    • 37484
                    I would check the ground contact for both the drum and the and development units. If there is developer in the coating on the drum, you will also need to replace the developer.
                    • xcopytech
                      • Aug 2006
                      • 1794
                      If you have solid magenta background then you do not have charge on magenta drum.
                      Check primary corona voltage and hvps.
