Toner difference
  • bojans
    • 1313
    Toner difference
    HI,
    Does anybody knows if we could use toner from Pro C 751 series in MPC 8002 series, and vice versa? Could it be the same toner?
  • davel
    • Oct 2011
    • 1095
    Re: Toner difference
    No.
    • bojans
      • 1313
      Thank you.
      Does any model share same toner with mpc 8002.
      On xerox printers you can find same toner in office and bigger models, only different package and rfid chip.
      I doubt that other manufacturers make unique toner for each model.
        Originally posted by bojans
        Thank you.
        alot do make different toner formulations between models.
        • bojans
          • 1313
          Found this posted by Slimslob in xerox part of forum:
          "I don't know about Brand X, but Ricoh toner bottles/cartridges usually have (in addition to the order number and lot number) have a small box with the "recipe" number. Usual on the bottom right of the label. If the recipe numbers match, the toner is the same, even if the size and shape of the bottles are different."
            • 37364
            From the second page of the Product Guide for the MP C8002
            The D135 series adopts new chemical toner in order to enhance image quality and meet the demand of higher image quality in commercial printers.
            New chemical toner means not used in any previous models,
              • 37364
              Thank you.
              The MP C8002 and MP C6502 are both the same basic model just different speeds. The Production version is the Pro 8100 series. Same toner just different quantity, yield and packaging.
              • anothertech
                • 1760
                Isn't the production version the Pro C5100?
                • Timmytronic
                  • Oct 2010
                  • 249
                  Originally posted by terramobil
                  The production version of Charis is the Pro C5100, but the toner is different to the MP C6502/C8002.
