MP C3002 not recognizing toner
  • StephenB
    • Aug 2015
    • 246
    This is a new post continued. I placed a Reman MP C3002 system, and when toner ran low, I used the Genuine Ricoh (841735) black toner. Display says " toner not set correctly".
    The unit now does accept Ricoh ( 842201) black toner. I even swapped chips from an empty Reman toner 842201 and placed it on a Standard 841735 , it accepts it. ( only it shows empty).
    I ran across previous posts where Techs inadvertently updated standard MP C's used the Ricoh Greenline engine firmware causing this same problem.
    Does anyone know if I can Update the current (Reman) Ricoh MP C3002 engine firmware with standard engine firmware to allow the Reman unit to accept standard Ricoh Black toner ?
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: MP C3002 not recognizing toner
    841735 Appears to be the correct K toner EDP for your geographical location and model.
    Black Print Cartridge MP C3502 | Ricoh USA
    842201 Has me confused, I do not know what P and RM is referring to (maybe the printer only model).
    Black Print Cartridge MP C3502P/C5502P | Ricoh USA
    As for the Greenline labelled machines they are just officially re-conditioned models.
    The firmware from what I'm seeing is identical.
    D1425116N / v1.11.04 is the last Engine firmware update for the MP C3002/C3502/G.
    Note
    I have had a faulty chip on a new toner bottle before, it's rare but it can happen.
    The fact you changed the toner bottle chips around indicates that BRB PCB is working, but it's still worth visually inspecting that you have no bent pins
    But I think it's more than likely you have the wrong toner.
    • StephenB
      • Aug 2015
      • 246
      Cipher,
      Thank you for your input. You are correct the toner that does work is the "P" toner #842201. I thought of the bent pins / contacts for the board reading the toner...not the case here. (positive this is a chip difference between toners)
      I read other / older posts where techs loaded / updated engine firmware (greenline) causing a standard (non reman version) not to recognize the toner.
      The only source I can find for Ricoh (842201) black toner is Ricoh direct. (too expensive)
      Is it possible to turn a Ricoh (Reman) C3002RM into a standard C3002 , so I can use regular Ricoh 841735 Black toner ? Is this done with firmware ? If so which firmware ?
      • mikadonovan
        • May 2008
        • 2931
        Ricoh MP C3502P/C5502P Black Toner Cartridge 842201 MP C3002-RM, MP C5502-RM | eBayMaybe here. (out of stock at the time of this post) or here.
        RICOH AFICIO MP C3502 TONER CARTRIDGE BLACK 28K / 842201
        NEVER ASSUME ANYTHING
        • StephenB
          • Aug 2015
          • 246
          Thanks Mikidonovan,
          I found that on Ebay as well, it is out of stock. And I did acquire a toner thru Ricoh direct (expensive) which works, so my "fire" is out for now.
          I'm looking for a way to convert a "Reman" version to a standard version.
          It's looking like that may be possible by updating the system firmware with standard firmware, not the Ricoh greenline firmware.
          I also don't want to "brick" the system. Just looking for someone who may have encountered this.
          Or a less expensive source for the 842201 black toner.
          • Cipher
            • May 2006
            • 1309
            Scrap what I posted.
            I was not aware Ricoh USA had modified their Greenline 02' range to take a different toner formula.
            • StephenB
              • Aug 2015
              • 246
              Thanks to all for your input. Ricohguy answered my "quest" , the greenline / Reman conversion may be possible by replacing the BCU, firmware and drum units. All due to a different type of toner used for Reman RM/ Greenline machines
              Polymerized (standard toner) vs Pulverized ( greenline / Reman RM).
              Thanks to all
              • QCCDUDE
                • Apr 2015
                • 9
                Hi Guys , I too figured out that you cannot use OEM black toner, you need to use the Ricoh "greenline toner" id 842201 for black , question is, do the other color toners need to be none OEM as well ? Thanks
                • skinnyb
                  • Jul 2008
                  • 291
                  They only changed black. The colors are still OEM original. I have been there done that many times.
                  Sent from my LM-V405 using Tapatalk
                  • QCCDUDE
                    • Apr 2015
                    • 9
                    Thank you for your Quick response,
                    • dalewb74
                      • Feb 2018
                      • 1167
                      personally i haven't seen this issue that you are facing. but something i did run into sometime back on one of my customers green machines. even though the box from richo said it was for the model machine. and everywhere i looked online, to make certain i had the correct part number said it was correct. sorry i don't remember which model machine, nor the part # for the black toner. but what i did discover was once you open it to install the toner. each toner had a sticker directly below where you insert each bottle. and the sticker part # for the black toner was not the same as what was listed on the box. once i ordered and installed what was on the sticker itself then it worked fine. might not even fix your issue. just an idea something you might wanna look at.
                        • 37628
                        A number of years ago, Ricoh USA had a number of new people working in one of their warehouses. They thought that the toner cartridges for the Pro 1357EX and those for, if I remember correctly, Pro 1356 looked the same so they took them all out of the 4 bottle cartons they come in and threw them all together in one bin. We had only sold the 1357EX and when we got in a new shipment of toner, over half of them were the wrong toner. Luckily they were both the same recipe number and I was able to get some empty bottles from one of our customers to funnel the toner into.
