MP C3003 Card Reader
  • ABS tect
    • Sep 2013
    • 511
    Hey yall hopefully this will be fast and easy...had a 3003 come in with a card reader attached to the front. I have had several of these before but for whatever reason i can't get this one off.
    Here is what i have done so far, hopefully you can see my error and let me know what else needs to be done
    SP 5-832-HDD (ALL)
    SP 5-846-046
    SP 5-801-10 AND 11
    FIRMWARE UPDATE
    In WIM i uninstalled all the java, directprint, etc...stuff that was under extended features in the configuration page (6 total). However under the same extended feature settings group below uninstall there is another option that says uninstall extended features programs or something like that...that has 45 things and it will only let me fill the bubble next to 2 of them to delete them.
  • copier tech
    • 8144
    Re: MP C3003 Card Reader
    Check the service manual, you just need to change an SP setting, from memory try Set SP5113-02
      • 37488
      If you are talking about the USB and SD card slots on the end of the control, they are part of the panel and cannot be physically removed. If all you want to do is disable their use, Scanner SP 1013-001 Multimedia Function Setting.
      • keithxxiii
        Just a tech
        • Nov 2014
        • 469
        From the administrator tools, enhanced external charge unit management, simply remove the selected applications. Or set SP 5113-002 to 0.
        Aye! Cut the crap
        • ABS tect
          • Sep 2013
          • 511
          Thank you guys the 5113-02 worked! Sorry for the late reply...i get so pumped when its working i take off and forget to repost Thanks again!
