C2503 w/ Wireless Option - No Printing
    • 37488
    Re: C2503 w/ Wireless Option - No Printing
    Originally posted by FrohnB
    Go into user tools and "Restore IEEE defaults". Had a customer that moved from one building to another, running on a wireless network, and I spent a couple afternoons there doing everything I could think of, and finally another tech told me over the phone to hit that "restore" in user tools "just to see what happens", and WOOFTA, Machine functioned normally after that.
    One problem there, if IEEE needed to be restored to defaults, the scan to email and pinging would not work either. The only instances that where IEEE 802.1x would used is be needed would if Ricoh's grossly overpriced WiFi adapter were installed or it needed to use Radius Dot1x authentication or a couple of other high levels of security. If Rich's WiFi adapter is installed, it will turn off the CAT 5 port, only one adapter can be used at a time CAT 5, WiFi, Bluetooth or fire wire. Watch the C2503 when a job is sent. If the data LED comes on briefly then turns off, some one may have changed user authentication for printing.
    • Stormhammer
      • Mar 2016
      • 150
      Turns out they had enabled user restrictions on printing. I really ought not to take two weeks off...
