Need some advice and handy tips for a MP C3004 with E-24B fiery
  • aktasson
    • Feb 2017
    • 201
    Hi there!
    one of our clients with a fiery criticised colors of some printouts. An onsite appointment was made for next week by our dispatch. Then, hopefully, I'll grab and get more infos about the situation.
    Is there a standard routine/procedure to check on the machine clients complaints? What are you doing or asking the customer?
    Thanks in advance.
    Cheers, Aktasson
  • davel
    • Oct 2011
    • 1099
    Re: Need some advice and handy tips for a MP C3004 with E-24B fiery
    Get the idiot salesman to explain why buying an expensive Fiery will not make a low volume office colour machine perform like a Production machine.
    • aktasson
      • Feb 2017
      • 201
      I also did not understand why a office machine offered with a fiery controller to the customer. And as it is, the tech ppl should turn wrong things to the bright side The other problem is we do not have a fiery either in our workshop, labroom nor showroom for testing.
        • 37444
        I agree on that. There is no need for a fiery on a non production machine.
        Unless your boss enjoys have unhappy customers, I would suggest have one on the demo floor. I would also you get Fiery Training from EFI.com, both service and sales.
        • tjvincent
          • 280
          I would also make sure the Fiery gets calibrated either with the test strips that come with it or preferably with an ES-1000 or 2000
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            AGREED....and make sure that all the Fiery patches have been done and it's up to date.
            But a Fiery on a low range '04 is lipstick on a pig I'm afraid.
            • copier tech
              • 8136
              Yes, a fiery on a non production model will not produce any better print quality than a standard model.
              It will however speed up print processing, large pdf files etc however not significantly to warrant the extra cost.
              • aktasson
                • Feb 2017
                • 201
                My boss has argued to this point that exactly 2 fierys on a office machine installed in the total field, and training programs does not make sense .
                In addition in my opinion, we should also have advanced knowledge to the topic color management firstly.
                • aktasson
                  • Feb 2017
                  • 201
                  I did the calibration with the strips during workshop preinstalltion. I will repeat that next week on service visit.
                    • 30088
                    Yes must be done anytime color is off , sometimes weekly most of the time there color files where tune to there previous machine. So they may have to adjust to a correct machine. Also was there last machine fiery based? Most color shops have someone there that knows how to calibrate a fiery
                      castrate the salesman responsible !!!
                      • guitar9199
                        • Sep 2016
                        • 1100
                        I suppose it's too much to ask to explain the difference between "Additive" and "Subtractive" color processing, and why an RGB monitor and a CMYK based paper printout MIGHT look a little different??
                        ...anyone?? ....anyone??.... Bueller??
                        • aktasson
                          • Feb 2017
                          • 201
                          That was not the question. Are you an RICOH fiery technician or specialist to give me some helps? Thanks.
                            • 37444
                            In addition in my opinion, we should also have advanced knowledge to the topic color and color management firstly.
                            I don't know about Ricoh-EU, but a couple of years ago when I took the EFI initial training, I signed up through the Ricoh Learning Institute which Ricoh-USA had contracted with EFI to provide. No cost to the dealer at that time.
                            • Athlontini
                              • Jun 2012
                              • 269
                              Depending on what variety of media (paper) they are using, you might need to set up media profiles in Command Workstation.
