spc830 pcu into mpc3002
  • Mark Bbb
    • Jun 2012
    • 1662
    I know there are a few (very old) treads that have treated this issue.
    The pcdu spc830 will not fit in a mpc3002.
    The pcu of spc830 will fit - without any adjustments - in a mpc3002.
    When a development unit spc830 is placed in a mpc3002, message "place pcdu correctly" will appear.
    Is there a way to fit a spc830 development unit in a mpc3002?
    Thanx.
  • Polarbear
    • Feb 2012
    • 1070
    Re: spc830 pcu into mpc3002
    If the unit fits, just transplant the loom. Ricoh likes to swop wires to cause this message....
    Sent from my SM-G950F using Tapatalk
    Press the GREEN button!!
    • Mark Bbb
      • Jun 2012
      • 1662
      Indeed, it fits in place perfectly.
      So, it will be a matter of wires.
      Anyone any idea which wire needs to be swapped?
      Again, thanks.
        • 37652
        Again, thanks.
        Try comparing the point to point drawings.
        • copier tech
          • 8236
          Thanx.
          You say yourself there are a few pots on this topic, so search & you will find your answer!
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            On the colour SPC830 printer units...swap the TD sensor from the existing pcdu to the printer unit and it will work.
            You can do the same for the Black printer unit but you'll still have to wire swap.
            Like Copier Tech stated...have a forum search and you'll find a guide on how to do the wire swap.
            • Mark Bbb
              • Jun 2012
              • 1662
              When the TD sensor is removed, will the developer not leak out?
                turn it upside down to change the TD sensor
                • copier tech
                  • 8236
                  Ofcourse so dont shake it about too much!!!
                  • fshead
                    • 2378
                    I have not seen any c830 yet but on the mpc300/400 series using the c430dn printer parts the TD sensor was double sided taped on and
                    there was no hole as it read between the plastic chassis...might be the same here..
                    My issue with flipping a dev unit upside down is all the "crap" gets stirred up and then you get mag roller voids..
                    IF that happens i get the ny times and dump the tank and sift it thru a plastic strainer.
                    It will catch all the big pieces..
                    • Oze
                      Ricoh Fanboy
                      • Jul 2008
                      • 1663
                      No...because it's just a board....not a piezo sensor.
                      • Oze
                        Ricoh Fanboy
                        • Jul 2008
                        • 1663
                        When you flip the pcdu you do it prior to removing any seals.
                        the SP830DN td sensor is just a board with no access to the dev.
                        • vickter200
                          • Mar 2018
                          • 18
