mp 2501
  • Gab
    • Aug 2015
    • 677
    mp 2501
    I replaced opc drum and blade(genuin) but after abot 1000 copies black lines on copies . So i replaced aGAIN opc and blade . But after 1 month (about 1k copies again) dark lines appeared on copies due to drum . I checked to find the cause but everything looked ok.The same problem appeared with an 2000 machine . To which i replaced it four times!!! And i couldn't find the problem.
  • copyaction
    • Oct 2007
    • 991
    Re: mp 2501
    Charge roller?
      Re: mp 2501
      Originally posted by copyaction
      Charge roller?
      YEAH! why replace the OPC..blade and not charge roller/corona?
      ***** lil trick..... keep some " Nu-Finish " car polish in your bag (orange bottle .. black label ) clean your charge rollers ( harder rubber.. not foam ) just a dab every couple inches...buff it out.. may take 2 tries *****
      STOP changing OPC's!
      • copier tech
        • 8238
        Re: mp 2501
        Yes replace ALL PM parts at the same time, inc the drum pawls!
        I trust you are using genuine Ricoh toner?
        • sandmanmac
          • 3990
          Re: mp 2501
          You really should consider doing something else.
          You're not listening or learning anything!
          http://www.copytechnet.com/forums/ri...ht=#post602542
          http://www.copytechnet.com/forums/ri...ht=#post601495
          http://www.copytechnet.com/forums/ri...ht=#post594337
            Re: mp 2501
            Originally posted by sandmanmac
            i doubt he is really a tech.... he isn't even trying.
            wants everything handed to him without having to think!
            • fshead
              • 2378
              Re: mp 2501
              • sounds like he needs to "wash machine out" with a garden hose on high pressure............
              • who needs a tech when you can wash away CQ issues
              • Mark Bbb
                • Jun 2012
                • 1662
                Re: mp 2501
                Not everybody is capable of understanding English, nor have they a large budget to work with like you guys!
                If you can't answer with respect, then don't reply.
                  • 37653
                  Re: mp 2501
                  He seems capable enough to type in English.
                  • sandmanmac
                    • 3990
                    Re: mp 2501
                    Budget??
                    I think I can speak for everyone here that none of us has a budget to just keep replacing drums every 1,000 pages just because! He's the one wasting the money!
                    It would seem to me that it would help his budget immensely if he paid attention to the people trying to help, and responded with some feedback on the results, and didn't just keep replacing drums improperly every 1 - 2000 pages and expecting a different result. That is, afterall, the definition of insanity.
                    • Oze
                      Ricoh Fanboy
                      • Jul 2008
                      • 1663
                      Re: mp 2501
                      If you need to wonder how a poster gets negative rep.....follow this post lol
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        Re: mp 2501
                        Budget??
                        You have a point.
