Ricoh mp c8002 sc 374-04 error
  • MStalkfleet
    • Apr 2011
    • 41
    [Error Code] Ricoh mp c8002 sc 374-04 error
    One of my techs has been battling this machine for months. Started in January with a SC402-64 after he pm'd the cleaning units. Turns out that when he reinstalled the yellow pcdu after rebuilding the cleaning unit, it kept catching the harness for the potential sensor and unplugging it. Once we got the harness pushed back up and reconnected, the SC402-64 was resolved. Now the SC374-04 pops up intermittently whenever you print or copy something with yellow. Is very random. We ran 5,10 (twice), 20 pages with no errors then tried to run 50 and it coded after 6 pages. Reset,tried again, got to 28 pages before it coded, tried a third time and got to 12 pages before coding out. After looking at Goose's guide we replaced the ID/MUSIC sensor board Friday 5/11/18. Input the new values, and ran all the SP modes per the manual. The transfer belt is new and Firmware is up to date.
    Am ready to scream. I went to school on this machine over 3 years ago, changed company's shortly after and haven't had to service these devices. Also, since we aren't a Ricoh Dealership, tech support will not help us. We are an MPS dealership and are HP & Xerox partners.
    Our client only has ONE of these devices out of the over 12,000 copier/printers in their facilities and the device only has almost 900,000 pages on it so replacing the device is not an option. Does anyone have a suggestion or any experience with this code? I am thinking the next step is to replace the developer unit and developer.
  • imaginemoko
    unTrusted Tech
    • Jan 2008
    • 289
    fix the customer first then fix the machine... its simple and makes life more easy.
    • mikadonovan
      • May 2008
      • 2931
      Re: Ricoh mp c8002 sc 374-04 error
      A logical next step, and make sure the center ID sensor is clean (it is used for the density adjustments).
      NEVER ASSUME ANYTHING
      • MStalkfleet
        • Apr 2011
        • 41
        Fixed!!! Turns out that when the pm was done and the developer was replaced, the tech couldn't run the TD sensor initialization due to the SC402-64 error. Once he returned yesterday (was away for training on HP device) and was assisted by the same team mate that helped me on Friday get rid of the SC402-64, he ran the initialization and all is right in our world again.
        Appreciate the input. We did check the service manual and read what the code meant and if we had known about the developer initialization not being done we could have probably avoided the SC374-04. Lesson learned.
        • kannuki2
          • Feb 2012
          • 398
          Hi, what was the fix for this error sc374-04?
          • mikadonovan
            • May 2008
            • 2931
            You might want to read the post right before yours................
            • kannuki2
              • Feb 2012
              • 398
              I don't have many of this machine. what is the procedure or sp to initialize it?
              • anothertech
                • 1762
                It's in the service manual.
                • kannuki2
                  • Feb 2012
                  • 398
                  So for anyone having this error code. I replaced a new Y development unit and developer bag and problem went away. This code said to replace td sensor and potential sensor are deceiving. its the yellow dev unit.
                    • 37375
                    The TD sensor is mounted on the bottom of the development unit. It seldom is shown separately in the parts catalog. With some models you could find the part number on the sensor but it still does not give the part number for the double sided mounting tape.
