Ricoh MP C2500 - jamming in fuser
  • savi0r
    • Sep 2010
    • 363
    [Jamming] Ricoh MP C2500 - jamming in fuser
    Hello. I don't have much experience with Ricoh so i am asking for your advice. I have a ricoh mp c2500 wich makes clicking noises in the fuser area and jams the paper there. After a good look, i saw that the timing belt is causing the noise. My guess is that the fuser is rotating too heavily and the belt just jumps gear teeth because it cannont rotate the fuser. Have you experienced this problem before? If it's a problem of lubrication, what must be lubricated (beside what is in the service manual) and does the oil supply roller have a role in this? Thank you.
  • sandmanmac
    • 3981
    Re: Ricoh MP C2500 - jamming in fuser
    Hmmm.....How about doing a PM on it, instead of looking for some magical solution like putting a drop of oil in some secret location
    It's probably WAY overdue, and maybe never have been done - at least by you, apparently.
    Bearings are probably seizing, gears wearing, etc., etc.
    • jonhiker
      • 661
      replace the fuser. there may be some missing teeth or a tooth on one of the gears.
        • 37453
        As the fusing unit progresses past the recommended past PM count the fusing and pressure rollers can start to change diameter. This can result in backlash between the gears driving the pressure roller. The double D of the pressure roller gear can also get worn again causing backlash. So when you PM the fusing unit, you must replace the belt, hot roller, pressure roller and pressure roller gear. It might be a good idea to replace all gears and bearings.
        • savi0r
          • Sep 2010
          • 363
          The fuser looks good, that's why i haven't considered changing it. It never jammed or caused any troubles. The gears aren't missing teeth. i checked that. I will try lubricating it and if that doesn' work, i'll rebuild it. Thank you all.
          • Mark Bbb
            • Jun 2012
            • 1662
            it is hard to diagnose a fuser unit with this info.
            Perhaps you can take a fuser from a another machine and see if it works fine...
            The cause could be anything...
            If the movement of the fuser unit itself is not blocked, so turning smoothly, then the problem could be in the machine itself.
            I did not have experienced problems with the fuser motor itself yet, but it is possible...
              WHAT DIDN'T YOU GET?
              REPLACE THE DAMN FUSER!
              just because it -= LOOKS =- good doesn't mean DIDDLY!
              • ridgemill
                • Sep 2017
                • 189
                Clicking noise on these models usually means that the pressure roller bearings need cleaning or replacing, or the pressure roller gear is cracked.
                Rarely, the belt can warp and cause a noise, however by the time this occurs the machine will throw a service code.
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  For God sake, take it easy boys!
                  What the heck is wrong with you all???
                  • Elmo
                    • Feb 2010
                    • 541
                    When all else fails
                    I Used To Live To Fix Things Now i Fix Things To Live
                    • savi0r
                      • Sep 2010
                      • 363
                      I got it the first time. Trust me on that. I'll be polite this time and explain the situation : the customer is a good friend that started a bussiness several months ago. I live in Romania. The machine price was like 250 euros. 500k on counter, but the print looked really nice. Now, here in Romania, an average pay for a month's work is about 350 euros. He had alot of expenses in the beggining and is still struggling. Maybe now you can understand why he kinda doesn't want to pay 700 USD (2 months worth paychecks) and why i am asking the questions i am asking. I am just searching for alternative options. Next time, i would appreciate some manners. It will do you good in the long run. Trust me on this also.
                      • Vintage tech
                        • Nov 2017
                        • 50
                        Bearings in those fusers prone to fail....
                        Dont bother trying to oil them up, just replace them, and as the other guys have said, while you have the rollers out check them for flat spots. Just not one of Ricohs finest fuser designs.
                        Best of luck.
                          • 37453
                          If you cannot make helpful replies, then do not criticize those who are trying to do so.
                            sniff sniff wawa
                              when someone is given advise by most in this thread.... then he just wants to put a "drop of oil" on it,deserves no " take it easy "
                              clearly he didn't take what was said to heart.
                              and as far a being polite? people that are offended need to take off the frilly panties and put some BVD's on!
