AF-2232C
  • Polo-022
    • Sep 2007
    • 484
    AF-2232C
    A bunch of thin black lines running from lead edge to trail edge, only from ARDF. This bunch is 2 cm wide and the image under this looks very fade. Optics are clean-slit glass also! PCU's in good condition.
    Well, this copier sometimes makes me laugh...i clean optics then i have one line on copies, one more copy?..3,4,5 lines, with the same document.
    I know there is a bulletin about controller PCB or BICU, but it is not so tragic!! Does anyone have the same experience???
  • Jomama46
    • 2900
    Slightly hold up the scanner on the front left side and run something thru the ADF. If this improves the copy, loosen the Stand screws on the left rear side and raise the left front of the scanner, then tighten the screws.
    sigpic
    A+; Network +; PDI+
