Scan to gmail on new MPC262SFNw
  • MitchD
    • Oct 2012
    • 164
    I had a new install last week on a SPC262 and for the life of me I could not get scan to gmail working. I contacted tech support and they could not get it to work either.
    Any ideas? I kept getting either "Net Communication error" or "Server Connection Error"
    Its a simple gmail email using smtp.gmail.com and Port 465. Issue was I cant find where to select SSL for auth.
    "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
    • 37643
    Re: Scan to gmail on new MPC262SFNw
    Check the network settings. If gateway or DNS are not correct, connection cannot cannot be made.
      • 30570
      go to system system settings, file transfer , select smtp on the window you should see smtp server and under that ssl on or off tab , just select on
      • MitchD
        • Oct 2012
        • 164
        I double checked and all settings are correct. Its in a home running Comcast and I used DHCP to acquire DNS and all other network settings.
        I have set up countless Scan to Email's and this one has me stumped
        • MitchD
          • Oct 2012
          • 164
          The new interface on the SPC262 is not like all the other RFG settings menu. There is no SSL tab to select or even a place to enter the info on the panel, I had to enter everything via WIM
          • teebee1234
            • Jul 2008
            • 1670
            You have to go to the Google account settings and enable "allow less secure apps". Go to myaccount.google.com, log in and go to "Sign-in and security" tab. Scroll down near the bottom and you will find the setting.
              • 37643
              Only needed if you are using port 25.
                • 37643
                If you do an internet search for "mfp scan to gmail" you should find this link to a Google Support document. Send email from a printer, scanner, or app - G Suite Administrator Help
                  • 37643
                  There is a possibility that Comcast could be one of the ISPs that block SMTP to any server other than their own.
                  • mincopier
                    • Dec 2015
                    • 289
                    Port 25, which Comcast blocks, on gmail only allows sending to other Gmail accounts. Enabling the "Use less secure Apps" disables two part authentication which Ricoh machines do not support. Be sure that "SSL" is tuned on. This is on the same page as the SMTP serve. Also try port 587. Gmail is wanting users to use "STARTTLS" which runs on 587. 465 is SSL. In some case you may need to add a self signed certificate.
                      • 37643
                      There are times when you have an MFP that only supports port 25 and an ISP that blocks port 25, your only option then becomes the use of a local relay such as Stunnel.
                      • MitchD
                        • Oct 2012
                        • 164
                        I was using port 465 with no luck. On the new c262 I could not find any place to select "SSL". I looked everywhere on the panel and WIM. I have set up countless scan to email machines in my 19 years as a RFG tech and never have an issue. Im going to dig through the SM and see if its a SP mode change or something silly like that. I will keep everyone posted.
                        • guitar9199
                          • Sep 2016
                          • 1100
                          Change the DNS to Google's settings.
                          Primary: 8.8.8.8
                          Secondary: 8.8.4.4
                          If I've ever had an issue with scan to email using Gmail, this usually resolves it.
                          • mincopier
                            • Dec 2015
                            • 289
                            Looked in the operators manual and the product support guide for this machine and it looks like it does not support SSL. Another option could be relay.appriver.com on port 2525.
                              • 37643
                              Ricoh's documentation for this model is not yet completed. Check the CD that came with the new machine. Normally step by step setup is in the setup guide or the Security Manual. There is no Security Manual available on line. There is a Setup Guide but it has about one sentence. I even checked the Global Knowledge Base and there are no documents for this model. Considering that this model is less than a year old, Product introduction date was June 2nd last year, it could be another 3 to 6 months before they have it available. Contact Ricoh's sales support for assistance.
