2501 light copies
  • Gab
    • Aug 2015
    • 677
    2501 light copies
    Copies are light. Is there any way to darken them . I have tried averything . The only way i found is decreasing
    the charge voltage . ?But when i turn off/on machine it returns to previous value. ||Is there any way to stabilize it or any other way to darken?
  • davel
    • Oct 2011
    • 1108
    Re: 2501 light copies
    clean optics, laser shield glass, new pcu.
    • Mark Bbb
      • Jun 2012
      • 1662
      Every 60K - 80K pcdu parts need to be replaced.
      what have you replaced jet? What is the counter?
      • sandmanmac
        • 3990
        I was starting to wonder if we'd ever here from Gab again. It's been over a week since his last CQ issue with a 2501!
          • 37628
          I see he still has no rep power and is up to 4 red cards.
          • Gab
            • Aug 2015
            • 677
            I have cleaned optics , shield glass also opc drum , developer have made about 10k copies.
            • Gab
              • Aug 2015
              • 677
              • copier tech
                • 8220
                Did you replace these parts with Genuine Ricoh?
                • quocve
                  • May 2012
                  • 20
                  If you have replaced the parts that do not solve the problem, then you should try adjusting the Gray Balance (R, G, B) values in Sp-4.
                    • 37628
                    Are you aware that this is NOT a color copier?
                    • davel
                      • Oct 2011
                      • 1108
                      Is it only copies, is the counter page ok. If yes your optics are dirty.
                      • quocve
                        • May 2012
                        • 20
                        Yeah I know, but that's what's in the document it's like.
