Updating FW on a MPC3003 with a SOP panel
  • fshead
    • 2356
    hi
    I just started to pick up MPC3003 AND MPC401SR with SOP panels.
    iM prepping one to deliver this weekend and need to do the FW updates.
    As I dont have the sd card SOP fw can i just update via the service mode?Is there anything you need to
    do to access FW via the service mode?
    thanks in advance
    • 35066
    Re: Updating FW on a MPC3003 with a SOP panel
    I"m not certain but you might to access to the @remote GUI.
    • fshead
      • 2356
      HI
      I am not sure what that means..
      I tried to update via Service mode and got E86 code..
      Is the firmware update option in service mode one that connects via the web and downloads the needed FW?
      I did not see anything in service manual.
      I figure if you were using the sd card why would you need this in service mode..
      thanks
        • 35066
        Originally posted by fshead
        HI
        thanks
        There are a couple of ways for updating firmware over the internet. One is @Remote. A dealer after signing up to use @Remote can then install the Center GUI and use it to login to the @Remote Center server in Japan to schedule firmware update downloads and various reports. After you get notification that the download has been downloaded, you can then arraign a date and time with the customer to install them using the options in Service Mode.
        • fshead
          • 2356
          thanks
          I was hoping it was more like other electronics where you can just access FW updates through the service menu.
          I am not a dealer nor have access to FW unless I find someone here or who
          I use to work with to help me..
          • copier tech
            • 7934
            The MPC3003Zsp & MPC401Zsp have Gen 1 panels, later models with Gen 2 panels you can update the firmware from the SOP menu.
            • fshead
              • 2356
              thanks
              Why would they have FW UPDATE in the service mode menu ?
              That confused as you dont service mode to update via sd card or using WIM .
              • copier tech
                • 7934
                thanks
                Because, as slim said above, you need the Ricoh @remote service running to access the firmware.
                You can update the firmware via WIM but you need to download the .rfu files first.
                • fshead
                  • 2356
                  ok
                  I got it now..
                  thnx
