Ricoh Pro C 751 'slow printing'
  • bojans
    • 1313
    Hi,
    After we send a file to print, Fiery e41 process it and it took a 5 mins to print on the machine.
    It happens from LCT and on heavyweight stock. If we change paper to weight 3 it goes fast.
    Re: Ricoh Pro C 751 'slow printing'
    Originally posted by bojans
    Hi, After we send a file to print, Fiery e41 process it and it took a 5 mins to print on the machine. It happens from LCT and on heavyweight stock. If we change paper to weight 3 it goes fast.
    all laser based life forms will run slower with a higher gram weight of paper being printed on ...
    you never mentioned what you are sending as a Job ( PDF - Word - ???)
    what is the size of the file?
    does it happen on EVERY file sent?
    • bojans
      • 1313
      Hi Phil,
      Thank you for reply.
      Problem solved.
      It wasn't set to print in productivity mode, so everytime they printed extraheavyweight, machine was waiting until fuser reach temperature.
