Re: aficio 1013
Yes
aficio 1013
Re: aficio 1013
This is a single lamp fusing unit, which there is not a separate lamp to heat the ends of the hot roller. If low power mode is set to level 3 the roller may not reach optimum temperature at the ends quickly enough. Also check fusing unit idling. If idling is off, hot roller will warn up quicker but heating may not be even and the pressure is not being heated. Idling is for when the first 1 or 2 pages are not fused completely.
Thanks!!!Leave a comment:
Re: aficio 1013
Hi there!
Take the fuser apart, check the plastik-bearings of the pressure-roller. They wear out, giving the problem you described. We allways change the roller and the bearings together.
Greetings...Leave a comment:
Re: aficio 1013
This is a single lamp fusing unit, which there is not a separate lamp to heat the ends of the hot roller. If low power mode is set to level 3 the roller may not reach optimum temperature at the ends quickly enough. Also check fusing unit idling. If idling is off, hot roller will warn up quicker but heating may not be even and the pressure is not being heated. Idling is for when the first 1 or 2 pages are not fused completely.Leave a comment:
Re: aficio 1013
Which part did you check? Tried in SpMode (Feed or scanner)?Leave a comment:
