ricoh sp5200s
  • stobby2
    • Oct 2013
    • 137
    ricoh sp5200s
    got small issue with sp5200s. Our guy is away so hopefully someone will know this. When photocopying the copy is very slightly too short so the top is exactly in line (vertically) but at the bottom the copy is slightly shorter by about 2mm. The copy then has a thin line at the bottom of the sheet from left to right presumably due to the copy length. I have been through the settings but cannot find anything on this. Any suggestions would be appreciated
    Dean
  • Kimi
    • Feb 2018
    • 105
    Re: ricoh sp5200s
    you will need to adjust the DF registration in service mode. You will find it under system sp > peripherals (from memory i think)
    • sandmanmac
      • 3990
      Re: ricoh sp5200s
      Dean
      Am I right to assume that this only happens through the ADF? Magnification is ok from the glass?
      Adjust ADF magnification adjustment under SP6
      • stobby2
        • Oct 2013
        • 137
        Re: ricoh sp5200s
        Cheers Kimi. I generally deal with Canon and Sharp so not used to this model. Now l know what l am looking for, shouldn't be a problem
        Thanks again
        • sandmanmac
          • 3990
          Re: ricoh sp5200s
          Wonderful, except that's not your problem.
          You clearly stated that the image is reduced, so adjusting registration won't resolve that.
          • stobby2
            • Oct 2013
            • 137
            Re: ricoh sp5200s
            Oh well. Back to the drawing board. The length of the image is the problem. It does not actually show when you look at the image. looks fine however if for example you copy the print count sheet the bottom horizontal line is approx 1 to 2 mm higher than the original if you hold them up to the light and you end up with another horizontal line just below it. On normal print this is fine. I had forgotten to check this on the glass so will check that out tomorrow as well
            Thanks again
            • sandmanmac
              • 3990
              Re: ricoh sp5200s
              Thanks again
              So , you're just choosing to ignore my solution above.
              Whatever
              • stobby2
                • Oct 2013
                • 137
                Re: ricoh sp5200s
                Whatever
                No No. Far from it. I will be trying your solution tomorrow. Just that l had a reply from someone else saying that your solution would not work. He has stated the following:
                Be assured we appreciate any help from you guys offered and have sorted numerous problems thanks to this site.
                Roger
                • sandmanmac
                  • 3990
                  Re: ricoh sp5200s
                  Roger
                  Wow! You're just not following this thread very well at all. I give up
                  • stobby2
                    • Oct 2013
                    • 137
                    Re: ricoh sp5200s
                    On the contrary. I will be following your advice tomorrow!
                      • 37628
                      Re: ricoh sp5200s
                      You might have far less problem by looking at the green cards, total posts and rep power when you have 2 people giving conflicting advice.
                      There 2 registration settings for the ADF, lead edge and trail edge. Lead edge set the synchronization between the lead edges of the original and copy paper. Trail edge adjusts the speed of the original across the slit glass.
                      • davel
                        • Oct 2011
                        • 1108
                        Re: ricoh sp5200s
                        You need to adjust DF magnification not registration.
                        • stobby2
                          • Oct 2013
                          • 137
                          Re: ricoh sp5200s
                          Many thanks for the info. Will be checking this out tomorrow. I Hate working on machines i am not trained on. Quite often when Messing about with settings you are not familiar can end up making things worse. I will be trying your suggestions and hopefully can sort it easily. If not have to wait for our Ricoh guy to come back
                          Again. Many thanks for your assitance
                          • PBR Dave
                            • Mar 2018
                            • 5
                            Re: ricoh sp5200s
                            Try this on you line. SP2103 1-4 set all 4 to 2.0
                            Hope it helps.
                            • sandmanmac
                              • 3990
                              Re: ricoh sp5200s
                              Hope it helps.
                              He clearly said that the copy is reduced by 2mm +/-
                              Those settings are for setting the erase margins and are entirely unrelated
