ricoh sp5200s
  • stobby2
    • Oct 2013
    • 137
    #16
    Re: ricoh sp5200s
    Originally posted by sandmanmac
    He clearly said that the copy is reduced by 2mm +/-
    Those settings are for setting the erase margins and are entirely unrelated
    Cheers Guys. Gonna be on it today and get back to you with results
    • sturmtrooper
      Copier Combobulator
      • May 2016
      • 587
      #17
      Re: ricoh sp5200s
      Wonderful, except that's not your problem.
      You clearly stated that the image is reduced, so adjusting registration won't resolve that.
      After reading his original comment several times it looks like the leading edge of the copy is fine, but the trailing edge is scrunched up and there is a line from the edge of the paper being copied.
      If it was magnification wouldn't the top of the image be off as well? Sounds to me like the trailing edge registration is off.
      • stobby2
        • Oct 2013
        • 137
        #18
        Re: ricoh sp5200s
        Unfortunately I am not the best at explaining issues however your description is exactly correct. The trailing edge has moved up slightly so it is the trailing registration out.
          • 37637
          #19
          Re: ricoh sp5200s
          SP4008
          [Sub Scan Mag.Adjustment]
          Adjusts the sub-scan magnification by changing the scanner motor speed.
          • stobby2
            • Oct 2013
            • 137
            #20
            Re: ricoh sp5200s
            SP4008
            That's excellent. Thankyou. Ran out of time to look at it today but will be on it tomorrow. All the advise is appreciated and l have a few things to try now
            • sandmanmac
              • 3990
              #21
              Re: ricoh sp5200s
              In a word. "no", and if the poster looks more closely at his output, he will see that the reduction is incremental as it goes down the page.
              I really hope that the 3 sample pages I'm attaching clears this up once and for all..
              I've seen this on virtually every SP5200 that I've run across, that had not already been adjusted - including the one sitting right next to me.
              I've printed a configuration page, then made a copy of it with the default ADF magnification of "0" and you'll see the line at the bottom and the fact that the length has been reduced (it's much more dramatic in the scan for some reason, and "yes" I'm aware that they are skewed)
              Then 3rd pages showsthe result after setting SP6017 to -1.0%.
              NOTHING ELSE HAS BEEN CHANGED.
              SP5200 Samples.pdf
              • stobby2
                • Oct 2013
                • 137
                #22
                Re: ricoh sp5200s
                [ATTACH]39768[/ATTACH]
                You've got it in one. Exactly what we are getting. Will sort it tomorrow and let you lnw outcome
                Many Thanks
                • stobby2
                  • Oct 2013
                  • 137
                  #23
                  Re: ricoh sp5200s
                  Hi
                  PERFECT!!!.
                  Thanks a lot. Took three minutes to sort. Set to -1.0% as suggested, now perfect. Thanks guys
                  • sturmtrooper
                    Copier Combobulator
                    • May 2016
                    • 587
                    #24
                    Re: ricoh sp5200s
                    I'll have to keep this in mind for the future, thanks.
                    • Tatteous
                      • May 2017
                      • 24
                      #25
                      Re: ricoh sp5200s
                      Am I right to assume that this only happens through the ADF? Magnification is ok from the glass?
                      Adjust ADF magnification adjustment under SP6
                      What I am to understand is that you have a magnification problem. Place your scale on the glass and make a copy of it. It the copy is the exact same length as the scale, then run the copy that you just made through the adf. Now measure the copy that you made through the adf to see if that is the exact same length as the scale. If it is, then you have a registration issue, not a magnification issue.
                      If this is happening only through the adf, then your SP 6*** will move the adf reg. But your base needs to be checked first. Make a big plus sign on a blank piece of paper and perfectly place it on the platen glass. The adjust lead and side edge as needed with SP 1001 for lead edge and 1002 for side to side reg for each tray.
                      Then once the base is correct, perform the reg adj for the adf.
                      • sandmanmac
                        • 3990
                        #26
                        Re: ricoh sp5200s
                        You really should try to pay attention, and read the entire thread if you want to help!
                        You're quoting me, and I'm not the guy that had the issue. I'm the one who already provided the solution, and was thanked for my efforts by the poster.
