MPC306ZSP - SC442-00 error
  • copier tech
    • 8136
    [Error Code] MPC306ZSP - SC442-00 error
    Hi all,
    i'm facing this error, will not clear.
    ITB looks fine nothing broken from what I can see, however I have ordered a new one.
    i'd also like to order the ITB HP contact motor & sensor but can not find this listed in the parts manual, it looks like it is located behind the main drive (from service manual) could anyone help me locate it in the parts manual please!?
  • aktasson
    • Feb 2017
    • 201
    Re: MPC306ZSP - SC442-00 error
    Hi all,
    [ATTACH=CONFIG]39760[/ATTACH]
    Don't order or change the contact motor first! Have a look to the sensor where is placed arround transferroller section side cover. Have a sensor check with the sp INPUT CHECK.
    • copier tech
      • 8136
      Which sensor are you referring to exactly?
      Machine started working for a few days now the error has returned & wont clear, no parts replaced yet!
      Machine also threw SC501 a couple of times too.
      • aktasson
        • Feb 2017
        • 201
        When you start the machine with power on, then you will hear one time shortly the itb contact motor. That's fine. But if you hear at power an a continuously run of the itb contact motor up to the sc code, then the machine could have a sensor problem from the ptr unit. It's placed side cover arround paper transferroller. There was also an rtb. I will search for it. And I would install the latest firmware.
        And Check if the side cover is correct closed and no damage is visible.
        • copier tech
          • 8136
          If you could find that RTF i'b be grateful, nothing on our UK site.
          All FW is current.
          From the manual the ITB contact sensor & motor this code relates to is in the back of the machine behind main drive? The only sensors around the PTR are for paper feed?
          • Mark Bbb
            • Jun 2012
            • 1662
            I remember there where some issues with the ITB on mpc3002... Timing disk faillure i guess...
            I don't know if there is any on this model...
            But it might perhaps help
            Good luck!!!
            • aktasson
              • Feb 2017
              • 201
              All FW is current.
              I know it's not sc442 but check this first for backup.
              [Symptom]
              Intermittend SC452 allmost overnight
              [Cause]
              Sensor below the Transferroller is not OK
              Second possibility: the Door close mechanism is not really close
              [Action]
              Change the sensor or change the Hook's for the Close - Door mechanism
              Do not change the Transfer Position Motor how it is written in Service Manual.
              This takes minimum 2h with no solution
              • copier tech
                • 8136
                [Symptom]
                [Cause]
                [Action]
                • aktasson
                  • Feb 2017
                  • 201
                  [ATTACH=CONFIG]39785[/ATTACH]
                  As i see there are different motors. How is the location, interferences over the power line or radio waves possible?
                    • 37435
                    SC501 is a problem (unspecified) with paper tray 1. Common cause is something interfering with the paper lift.
                    • copier tech
                      • 8136
                      • aktasson
                        • Feb 2017
                        • 201
                        All FW is current.
                        Have you found in the meantime the cause of sc442?
                        • copier tech
                          • 8136
                          I have removed this machine back to my office & installed a new machine for my customer.
                          However been using the faulty machine every day the error(s) have not returned so no idea!
