Ricoh 6002 DF Jams on mixed sizes only
  • ChrisG
    • Oct 2013
    • 181
    Wondering if there was any firmware updates for this condition?
    Jams shows at the reg sensor (006) every time and it's obvious by the buckle in the paper, that the rollers never turned on. Tried swapping the two motors in back and got the same results. All sensors check. Again it only seems to be an issue when doing mixed sized originals. Can run short edge LTR and LGL all day on copy,scan, and/or df free run.
    Was going to read the theory of operations for that particular DF but couldn't find it anywhere in the service manual.
    Help always appreciated.
    Chris
    TJL Copy
    • 37456
    Re: Ricoh 6002 DF Jams on mixed sizes only
    Do you have mixed size originals turned on? If not, it will assume the 6002 will assume that all documents in the set are the same length.
    • Iowatech
      Not a service manager
      • 3930
      Slimslob, I've been out of the field for a while, and am probably not the sharpest utensil in the drawer, but if the size sensors in the feed tray (SADF2, p 30 i 26) need cleaned wouldn't it cause something like that? Something like that used to happen on an older machine that I actually worked on. Stupid dusty truck dispatching office.
      No, wait, the office wasn't stupid, the dust was, while the outside of that machine always looked remarkably clean, the dust apparently always went straight for the sensors in the ADF feed tray for some reason. D'oh.
      Sorry if this was a dumb comment.
        • 37456
        I would agree if it wasn't mixed sizes. When you select mixed size for originals, it uses the time for each of the originals to pass the skew sensor. With mixed off the length sensors on the feed table gives the length of the first and all the rest are assumed to be the same.
        • NeoMatrix
          Senior Tech.
          • 3513
          ADF Jams ... ~~thinking ~~~~
          Mixed length originals through ADF verses the Auto paper detection function of paper tray settings.
          Are the paper trays set to fixed sizes and the scan originals don't match the paper size of the tray?
          There was and old post about MP6001-2 series and DF jambs.
          You may like to search CTN for MP C6000 ADF jambs.
          hang on <tap, tap, tap>
          MP6000 ADF runs 3 or 4 sheets then goes int ADF jam.
          http://www.copytechnet.com/forums/ri...tml#post314901
          I can't find the post I'm looking for. The above will keep you busy...
          HTH
          • MIKON
            • Jul 2015
            • 186
            Try cleaning shaft and gear where arrow is
            • dpoutz
              • May 2011
              • 78
              No real fix change dpi for scanning and mixed size originals but the main thing is using superlube or tri flow and clean and lube any bushing and 1 way you can on the front and back of adf this definitely will help the issue
              • aap
                • Feb 2022
                • 2
                Hi! So what is the real fix for this problem? Cleaning and lubricating?
                  • 37456
                  This thread was four and a half years ago, dead and buried grave robber.
                  • aap
                    • Feb 2022
                    • 2
                    And so what? I've got this problem right now! And this thread is the only info found.
                    That MFU has done about 4 million. And this problem is still not permanent, but more and more frequent.
                    Tomorrow, I'll try to clean and lube all sensors and gears. May be, do some resets.
                    What can I do more?
                    Thank you, for your reply!
                    • anothertech
                      • 1766
                      ADF firmware should be 1.020:02
                        • 37456
                        What can I do more?
                        You do what everyone else with any form of intelligence foes, you start a new thread.
