printer driver settings lost in windows 10
  • Mark Bbb
    • Jun 2012
    • 1662
    At one host the PCL6 setting and port number setting of the Ricoh mpc3001 printer is automaticily (?) set to "WSD-port" and "universal printer driver", sometimes. I think this happens when customer shuts off the machine.
    Anyone has seen this before?
  • Leyahné
    • Feb 2016
    • 44
    Re: printer driver settings lost in windows 10
    Are you printing via the network, switch of the snmp on port config put it on raw and then test. Windows10 puts in lpr print que as lpr
    • francisco
      • Nov 2009
      • 168
      disable WSD settings via WIM in TPC/IP
        • 30123
        Windows will auto discovery and install printer NEVER use Universal driver or WSD port to print
        • Mark Bbb
          • Jun 2012
          • 1662
          If I didn't understand that, would i have asked this question?
            • 30123
            Then why did you ask it? if you all ready knew the answer
            • Mark Bbb
              • Jun 2012
              • 1662
              Florida: to much sun today, i perusme?
                • 30123
                Brilliant
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  I have tried, but it won't accept the change:
                  "Service unavialable 503" or "machine bussy" or "wrong parameter",...
                  I can not change this parameter!
                    • 30123
                    Control Panel (icon view)> Network and Sharing Center > Change advanced sharing settings (on left side of screen)
                    Under: Private > Network discovery
                    There is a box that says "Turn on automatic setup of network connected devices."
                    Uncheck that box and click "Save changes."
                      you are logged in as ADMIN when trying this correct?
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        Phil, yes, it is correct. Is that the issue?
                        • Mark Bbb
                          • Jun 2012
                          • 1662
                          If i uncheck this, customer might get other problems, no?
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            by the way, is it your "guild feeling" that makes you post this info?
                              • 30123
                              Nope just helping out a non IT tech with the correct information enjoy no worries
