ssd & hdd en ricoh
  • COPYMAC
    • Feb 2011
    • 13
    [Error Code] ssd & hdd en ricoh
    Hello, install a ssd on a Ricoh mp 2852 machine, it works but when you come back from the stand by it indicates sc861 problems with hdd.
    will any firmware be necessary?
    regards
  • LNorris
    • Sep 2008
    • 645
    Re: ssd & hdd en ricoh
    did you follow the steps in the manual to install a hdd? i think there are 4 sp modes to enter when doing so.
    • COPYMAC
      • Feb 2011
      • 13
      if I did (5853), when using a normal hdd the machine works fine, but when placing the solid state disk and when returning from stand by it is delayed and induca sc 861. greetings
      • LNorris
        • Sep 2008
        • 645
        ive never tried the ssd hdd. not sure how they react. i cant help with that part, sorry.
          was it equipped with the SSD to begin with or just a SATA drive?
          might wanna try a regular HDD.
          • sandmanmac
            • 3990
            Agreed. The standard HDD is SATA, and I doubt that it supports SSD
            • COPYMAC
              • Feb 2011
              • 13
              no, it came with normal hdd but failed (sc872). So I installed an SSD and it works but when going to standby and back it indicates SC 861, it must be some firmware I think.
              regards
              • sandmanmac
                • 3990
                regards
                That's just terrible logic, man.
                You had an HDD error, replaced the HDD with, in all likelihood, an incompatible one, and now you have a different HDD error.
                ...Not to mention, that it seems you didn't even attempt to to format it in SP mode.
                Why would you not take 90 seconds and swap in the style of HDD it was designed to use!?
                By the way...in the video you posted you only put the machine into standby mode, and didn't even wait for it to completely shut down, so you're not even rebooting it!
                • COPYMAC
                  • Feb 2011
                  • 13
                  is to experience new options, I have replacement HDD. pro today endia the ssd are working better. so it's good to try ottar altenativas.
                  regards
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    regards
                    We're all for experimenting with new alternatives but when they don't work and they cause a machine fault you need to go back to what you know.
                    The machine does NOT support SSD so you just need to bite the bullet and fit a standard SATA HDD...you tried though...props for having a go.
                    • anothertech
                      • 1771
                      Try turning off standby mode.
                      • rthonpm
                        • Aug 2007
                        • 2860
                        There's probably no support for many of the firmware features that SSD's try to use to balance out writes and I/O with the operating system. You're not dealing with a full OS like Windows or *Nix. You're dealing with an embedded OS with a very small subset of features built expecting a specific set of hardware. Kudos for trying like Oze says, but you're trying to force the machine to use hardware that's likely trying to give it information that it can't understand and/or process.
                        Final thought: with the amount of writes that an MFP does for every job you're going to kill an SSD much faster than you would a standard HDD.
