MPC 3001 SC 547 error code
  • ttean
    • Oct 2010
    • 32
    [Error Code] MPC 3001 SC 547 error code
    MPC 3001 give SC 547 code.
    Have replaced a whole heater unit and power supply unit still give the same code.
    According to this error code heater unit not heating up.
    Can IH Inverter Board or IH coil Relay Board gives this error code
    Any suggestion will be much appreciated if anyone has come across this issues.
    alvin
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: MPC 3001 SC 547 error code
    check for the continuity of the IH coil. It is also possible that IH inverter board is defective.
    Nobody is perfect..
    • keithxxiii
      Just a tech
      • Nov 2014
      • 469
      Agree.. I have experienced this problem before.. It was a defective IH coil unit. Check the continuity of the coil before replacing
      Aye! Cut the crap
      • ttean
        • Oct 2010
        • 32
        Thanks I will checked that.
        alvin
        • ttean
          • Oct 2010
          • 32
          I will checked for defective IH coil unit.
            • 37532
            It could also be the thermostat on the IH coil assembly, see caution in the service manual for replacing the coil. You can check the thermostat by disconnecting from the inverter board. Of course Ricoh does not sell just the thermostat. I have had success bypassing the thermostat at the inverter board while I wait for a new coil comes in.
            • nikshamsul
              • Jul 2020
              • 1
              [QUOTE=slimslob;607369]It could also be the thermostat on the IH coil assembly, see caution in the service manual for replacing the coil. You can check the thermostat by disconnecting from the inverter board. Of course Ricoh does not sell just the thermostat. I have had success bypassing the thermostat at the inverter board while I wait for a new coil comes in.
              CAN TRY TO PUT THE THERMOSTAT IN THE FREEZER OR CAN TRY TAPPING SO THAT THE THERMOSTAT CAN BE TURNED ON{USING MULTIMETER}
              • luca72
                • Oct 2017
                • 1784
                alvin
                in addition to everything they have suggested, I would try to replace the front panel switch (s), once I went crazy one day for a fucking "signal cross zero" del cazzo.
                "I'll be back"
