Ricoh mpc 5000
  • vicalvarez
    • Mar 2014
    • 33
    [Error Code] Ricoh mpc 5000
    I have this problem sc565 I change thermistor and same problem anyideas
    Sent from my SM-J105B using Tapatalk
  • Xcelsior
    Ex-Tech
    • Jan 2017
    • 24
    Re: Ricoh mpc 5000
    Assuming the thermistors are in place properly and the code was reset after with SP 5-810; Check that you didn't pinch a wire, then check the Thermostats, then check the lamp.
    If you can't get continuity on the Thermostats with a Voltmeter then one popped. You can 'reset' them but they are cheap enough to just throw in a new one.
    Then check that the lamp is in the proper temp range (SP1-10x?) assuming the code doesn't pop instantly on power up.
    Previous Ricoh Field Service Tech II - November 2017.
    • TonerMunkeh
      Professional Moron
      • 3865
      Re: Ricoh mpc 5000
      The pressure roller thermostats have jumped. Reset or replace them.
      Hit it.
