MP C5503 Slow RIP
  • iscott
    • Mar 2010
    • 344
    MP C5503 Slow RIP
    Ok I am stumped and 2 Ricoh trained Microsoft certified Techs are stumped as well.
    I have a MP C5503 that has been in service for 2 years.
    The other day my tech replaced the fusing sleeve assembly.
    The customer says that when he did this that's when the problem started.
    We think it is just a coincidence but thought I should mention it.
    If you send it a color job it takes forever to start printing approximately 1:07 minuets
    It doesn't matter if its one page or 25. It starts receiving the job immediately and warms up but does nothing for the next 60 second.
    The delay only occurs when printing copies fine and prints meter sheets as usual.
    Looked at the Fuser temps and everything was in line.
    Here's what I have tried
    New Hard Drive
    New Memory
    Printing direct from my laptop to the printer (Not on their network)
    Reloading Universal drivers
    PS 3 Driver
    PCL 6
    Changed the IP address
    Downloading documents before printing
    Printing word documents
    Nothing changed
    The only thing I noticed is that on one occasion I printed a test page and it took a long time to print I printed another test page immediately after that one printed and instead of the 1:07 it printed in 14 seconds.
    That's all I know
    Almost has to be on the control board, but no one has ever heard of a control board issue causing this symptom.
    Any thoughts
    • 30291
    Re: MP C5503 Slow RIP
    Is it slow with copies or just printing.?
    If it slow on copies fuser maybe warming up to temp before printing or making copies
    you can check network settings look for network speed setting 1gigbit 100mps 10mps etc.... half duplex etc....
      • 37529
      If you read iscott's original post carefully you will see "The delay only occurs when printing copies fine and prints meter sheets as usual." I've underlined the portion you apparently missed.
      • mincopier
        • Dec 2015
        • 289
        For slow printing what I have always checked, and you may have also.
        Be sure port is the IP address of the copier, no WSD port.
        On the Port tab under printer properties there is selections for RAW and LPR. Try changing these
        Use the current driver, not the universal
        Update the firmware
        Check network speed at the copier, User Tools, System Settings, Interface tab, Ethernet speed? Looked on an 816, but should be close
        Did the laptop print normally? Saw that you tried but did not understand if it was normal or same problem.
        That's all I can think of at the moment
        • aktasson
          • Feb 2017
          • 201
          Do you have used the customers file pdf/doc to print it out from your laptop over a crossover cable to the machine? And how was the result of speed, exactly the same time as customers environment?
          Ethernet mode and speed at auto configured?
          Package and firmware romdata files for engine, system/copy, networksupport up2date?
          For warm-up and wake up problems from the fusing it would be same manner also for internal printouts (smc list), printer testpage, or for the copy mode. That will not be the problem.
          • vickter200
            • Mar 2018
            • 18
            i had a similar issue, all network ports and drivers where good. i did all the trouble shooting with boards etc. As soon as i removed the finisher the units stared to function good. Did some history on the machine and come to find i installed the wrong fusing sleeve, i used the 30/35 ppm sleeve. i swapped it with a used 45/55 fuser and bam worked great. hope this helps.
            • copier tech
              • 8170
              In your title you state mpc5503 “rip” Did you replace the hdd & ram in the fiery or machine?
              You didnt mention firmware, i’m assuming you have loaded the latest patch fw recently released?
                • 30291
                Needle in hay stack. Would talked to tech and go over everything the tech did onsite. Everything! Double check all parts installed correct part etc... and any sp mode settings. Any user modes entered on-site etc......
                • iscott
                  • Mar 2010
                  • 344
                  Have made another discovery. It is in the machine for sure. Prints and copies B&W Fine But when it prints color it sits for approximately 1 minuet before it stars printing in copy or print mode. It also does this if you print a config page that has color in it (ie PS config page)
                  Whatever it is it does not affect color scanning that part works fine.
                  One post ask if perhaps the we put it the wrong fuser sleeve assymbly. Would that not also show up when printing B&W? And the Fuser temp numbers are in line also.
                  • semi
                    • Sep 2008
                    • 195
                    Double check pressure roller thermistors,Had one bent at a angle not contacting press roller causing slow colour printing-just a thought.
                    • copier tech
                      • 8170
                      Did you notice my question?
                      • vickter200
                        • Mar 2018
                        • 18
                        i posted the fuser. Same with me Black was working fine only color had the issue. Unplugging the finisher somehow helped. But swapping the fuser worked.
                        • Lagonda
                          • Aug 2008
                          • 1649
                          Ditto, had this one as well.
                          OK when putting a copy into the internal tray but took for ever when putting a print into the finisher. swapped the output trays around and the photocopies into the finisher took ages. Lots of head scratching later and it turned out to be a thermistor bent away from the sleeve surface.
                          Don't ask me why it was more heat sensitive when using the finisher, never worked that one out.
                          • Garry
                            • Jun 2009
                            • 11
                            we have had this issue twice now. on both machine it turned out to be thermistors & on both machine, they had just had there sleeve's replaced
                            Hope this helps
                              • 37529
                              Hope this helps
                              Was the sleeve replaced by the same tech on both?
