MP201spf - No std paper set
  • kalaris
    • 70
    Hi!
    I need to set the second optional drawer in the A5 format in the MP201. Do you know if as in the previous mp161 with parameter 5112- (No std paper set) can the optional cassette be set with non-standard formats?
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 589
    Re: MP201spf - No std paper set
    Originally posted by kalaris
    Hi!
    There is no SP5112 in the service manual for the 201. However I think you will be able to manually set that paper size in the settings menu without changing anything.
    • kalaris
      • 70
      Unfortunately in the machine in the second drawer manually you can only set up "A4r- 81/41/2
