SC 551-03 (MPC 2503SP)
  • sharpmind
    • Sep 2009
    • 478
    Guys, have you encountered this kind of problem? Replacing the fusing unit will solve the problem but it cost much. My question now is, what particular part in the fusing unit causes the error?
    Re: SC 551-03 (MPC 2503SP)
    it is a pretty specific code what does the manual tell you?
      • 8131
      From the manual:
      Remedy
      • aktasson
        • Feb 2017
        • 201
        SC551-03 A Edge NC Sensor Short-circuit
        AD value: 0-13 (FB voltage: 0.000V-0.041V) (*3) is detected for (t14) seconds continuously.
        Detection period: 100 ms, detection frequency: 10 times or more.
        • NC sensor short-circuit
        • Connector disconnected
        • Replace the NC sensor
        • Reset the connector
        • Replace the connector
        • Replace the fusing unit
        • sharpmind
          • Sep 2009
          • 478
          NC sensor means non-contact sensor (AW100150 and Aw100151)...PROBLEM SOLVED..!
